New Wheels Offset Suggestion
on
OK first off i am a total space cadet when it comes to the offset selection of wheels, i would appreciate every suggestion...Thanks
I am getting the Axis Shines F:19x8.5 // R:19x9.5 the offsets available are:
Fronts: (15) (35) (45)
Rears: (20) (40)
As for the tires, i already have the Toyo - Proxes T1R – (F) 245/35-19
(R) 275/35-19
I am at stock height at the moment, but plan to lower using the Eibach Pro-kit
Rears: (20) (40)
(R) 275/35-19
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Senior Super Moderator
If you choose the +15/+20 route, your fronts will stick out 21mm farther than your stock rims (assuming you have 06+ Touring v2 wheels) and the rears will move out 25mm. Even with the Pro-Kit, you shouldn't have to worry about rubbing issues but like sdZ33 said, every car is different.
on
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
