I ordered ichiba but did I received knockoff
Old Sep 29, 2010 | 06:19 PM
kevincat's Avatar
kevincat
Default I ordered ichiba but did I received knockoff
So I ordered a new set of 20mm ichiba v2 from west Covina Nissan and I just received the spacers today. What I'm wondering is did I received the knock off nobeand spacers. I thought that the bolt of the ichiba uses a special socket with four pins? The one I received uses a regular socket and it didn't come with any sockets. Any indication on the spacer itself that state that it's real ichiba or not?
Old Sep 29, 2010 | 06:20 PM
kevincat's Avatar
kevincat
No brand* I'm on my phone so I can't edit
Old Sep 29, 2010 | 06:22 PM
HeyItsDan's Avatar
HeyItsDan
I have Ichiba v2 spacers and they came with regular bolts.
Old Sep 29, 2010 | 06:29 PM
HeyItsDan's Avatar
HeyItsDan
Mines actually looks just like the ones in this thread:
https://my350z.com/forum/wheels-and-...s-spacers.html
But after doing some research, I did notice that there were some that came with special bolts with a key. I'm not sure but maybe there are 2 different kinds?
Old Sep 29, 2010 | 06:44 PM
Nexx's Avatar
Nexx
sounds like you got the version one with the extended studs that you have to use to replace your stock studs.
Old Sep 29, 2010 | 06:59 PM
jduet's Avatar
jduet
My ichiba spacers use a standard socket. The project kics I owned used a 4-prong key.
Old Sep 29, 2010 | 07:36 PM
kevincat's Avatar
kevincat
Mines the v2 so I don't have to do the replace the lugs. Funny thing is that I purchase the v1. And realize that I had to remove the wheel bearingto get the extended lugs to fit so I solder it to get the v2.
Old Sep 29, 2010 | 08:19 PM
terrasmak's Avatar
Just return them and get the V1 before its to late.
Old Sep 30, 2010 | 07:34 AM
str8dum1's Avatar
str8dum1
regular sockets are better than that 4 pin mess anyhow. my 4 pin tool is all bent
Old Sep 30, 2010 | 01:37 PM
vlado_t's Avatar
vlado_t
the V2 10mm and 15mm come with the four pin hole sucket. The V2 20mm amd 25mm come with regular sucket, which is better.
Old Sep 30, 2010 | 01:44 PM
kevincat's Avatar
kevincat
great thanks guys.
Old Sep 30, 2010 | 01:47 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I have the 10mm V2 and it's a regular lug. Project Kics have the prongs.
Old Sep 30, 2010 | 01:54 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
wheel bearings are untouched to install v1 spacers
Old Sep 30, 2010 | 02:13 PM
kevincat's Avatar
kevincat
it was impossible to squeeze in the long studs into the hole. i have tried every which way and none of them seem to work. i had to remove the emergency brakes assembly to get enough room for the longer stud
Old Sep 30, 2010 | 02:27 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
i can tell from your pics........fake.
Old Sep 30, 2010 | 02:49 PM
kevincat's Avatar
kevincat
i was trying to upload pictures to my photobucket thru my iphone but my phone freezed and i had to go somewhere. if you still need them then i will be glad to provide
Old Sep 30, 2010 | 02:54 PM
kevincat's Avatar
kevincat
Old Sep 30, 2010 | 03:41 PM
terrasmak's Avatar
That's the V2 just punch the studs out and order some ARP studs to make them like the V1 spacer.
Old Sep 30, 2010 | 04:23 PM
kevincat's Avatar
kevincat
how long are the arp studs. because i really dont want to go to the trouble of removing my calipers and my rotors only to realize that the stud will not go in without taking out more components of the brakes.
Old Oct 1, 2010 | 10:30 AM
Z1 Performance
Former Sponsor
3 inches
