17x10 +25 fitment help?
i'm new to the forum. could someone confirm that 17x10 +25 with 275/40/17 tires fit the 350z? I did some quick search and i saw Axelerate's car... he's not active in the forum anymore and i can't find more info... thanks.
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
I run 17x9.5 +27 with 275 all around. Fits without issue.
You shouldnt have a problem. |
I had a 17x10 +25 with a 305/35/17 in the rear with no issues when I was at stock height.
You'll be fine.
Anyone notice this guy has been a member here since 2003 and it took him 7 years to make a post? haha that's epic |
Should fit just fine. I run 275/40 on a 17 x 9 +30 and the person I bought them from ran 275/40 on 17 X 10 +12 with no issues (both are square setups).
Fits fine up front and rear. You could also run spacers if you want out back
I was hoping this would happen. Looks like another gonnaget dead end.
i have 17x10 +12 with 275.
