will 20x11 +15 fit in the rear?
guys i need some help here. im planing on buying wheels for my 350z. The one im about to get have the specs of 20x9 +15 in front and 20x11 +15 in the rear. My car is currently sitting on stock suspension. would these wheels create any problems such as rubbing?
thanks for all the info's |
I have a feeling that your going for the XXR 526's... Yes it will fit, but if your at stock hieght, they will stick out past the fender... You might want to look around and see what you might need to get done to make these fit properly... (camber)
Not sure about rubbing, but I wouldn't bother to put them on until your lowered or it will just look weird. My $.02
it wont be that bad. I ran a 19x11 +18 on springs and had to run 10mm spacers on a 255 and was still sunk in....
1 Attachment(s)
run a 20x11 -30 and it will be perfect with -3 camber and a 245 tire
My Z with 19x11 +18 spaced to +8 still sunk on a 275/35/19 Attachment 431163 |
Depends what size tire you want to run. If you run a proper tire for an 11" wheel, which is at least 285 and up to 315, it will rub without some work.
Originally Posted by sdZ33
(Post 9169324)
Originally Posted by TehkMob
(Post 9169498)
My Z with 19x11 +18 spaced to +8 still sunk on a 275/35/19 https://i749.photobucket.com/albums/...z/DSCN0651.jpg |
it will rub
(Post 9169496)
Originally Posted by A-Lo26
(Post 9169765)
nice ride! anyways the wheels that im getting only comes in 20x11 with the offset of +15. but the 20x9 comes in either +15 or +35. im planning on running them on a 285/35/20 and 235/35/20
they are XXR 526s.. thats the size and offset choice for the new popular bandwagon wheel that BTW isnt even here in the US yet.. i bought a set and after 3 months i cancelled.. bought some real wheels.. Forgestars. jsut my 2 cents man....
But for a budget, they are dope i guess.. they are heeeeeeeeeavy tho.. well over 30 lbs. On stock suspension? no no... will look crazy.. please at LEAST buy crappy ebay springs and drop your car... then take a metal pipe and slowly roll your own fenders..youtube it... its free and then your wheels will fit. |
tehk.... nice stance and diffuser.. looks good.
BTW OP, his fenders are rolled in the back.. see that razor edge? Thatd be it. Not a tuff mod.. |
(Post 9169765)
(Post 9169765)
i've run a 20x11 with a -11 rear offset before with no camber kit and only fenders rolled..my tires were stretched to 255/30
Originally Posted by BoomerZ33
(Post 9169884)
so what wheels are they? hope its not chrome. also i would go with a 275 width in the rear.
those are some sick wheels. I would check out this website....
http://rimtuck.com/thumbnails.php?ve...clemodel=350Z& its a great tool to find out which set up you want to go with. It has pictures and the specs of wheels and tires they run. And they also have other imports as well. |
Did it work
(Post 9169232)
thread is 5 years old bruh
