275/40/18 Front, 275/40/18 Rear: Any probs?
on
Ok i ordered a set of 18x9.5 +22 wheels all the way around. Plan on running 275/40/18 all the way around too. Going to be using this setup for autocross and HPDE's...it's a compromise, can't afford to have one 17" set for autox and one 18" set for HPDE's and street.
For those running 275's in the front, what are your wheels specs (width, offset) and do you have any issues with rubbing the inner wheel well? Thanks in advance.
on
u may need to upgrade with a Nismo or other brand power steering cooler...
i think one of the members here "2003z" usues 275's fronts and has upgraded his PS cooler also
SFZCC
on
on
I use 274/40-17 all around at HPDEs and track events... have not noticed any problems with power steering overheating, but that does not mean it won't happen.
Probably not a bad idea to upgrade the power steering fluid cooler. Just one more thing to spend money on!!
PeteH
PeteH
on
thanks guys for the info...i had been thinking about the Nismo power steering cooler and you guys have confirmed it. at least the cooler won't break the bank...one of the more affordable parts from Nismo.
on
You're giving up the stagger. I don't know which model you have. If it's the base, probably no issue. If anything above the base, the VDC or Slip control could give you some grief.
Lou
Lou
on
Lou
Lou
on
I have the enthusiast...no VDC. And as any autocrosser or road racer knows, first thing after ignition is turn TCS off. I made the mistake of leaving the TCS on for a run...that really sucked. I am more looking for balance and having the same setup front and rear is more ideal for autox which i spend most of my time with (HPDE's few and far between).
on
on
Like mentioned above, I run 275/40s all around and I boiled my power steering fluid at a short, turn-intensive track. There was fluid all over the underside of my hood, so I got the PS cooler.
on
Have you been on the track since? Did it make a difference?
on
Ordered my Power Steering Cooler Kit from Performance Nissan. Great prices. The other dealership in Cerritos was almost 50% (yes 50%) higher and they wouldn't match.
on
Wow...i ordered the nismo PS cooler kit from Performance Nissan yesterday, come in to the office this morning and there is the package waiting for me. Granted I'm in LA, short distance from Duarte but that is fast.
Thanks to Jenny at Performance Nissan!
04-04-2016 07:52 AM
