SF Winning Akebono Clearance
Hi all,
I'm looking at a set of SF Winning rims to replace my Work XSA 04C. I need a bit of info though on bbk clearance. The volk wheels are 19x9.5 +19 and 19x10.5 +17, Front appears to be the A disk model, which is mentioned for clearance on 350Z, rx7, Supra brakes, etc. Is my assumption correct that these will not clear the Akebono 370Z sport setup? I know we're going back a few years for the wheel model, but any info or pics would be much appreciated here |
I'm on SF Challenges and Akebono brakes which are very similar to your SF Winning. Unfortunately I dont know the offset of mine or the disks, all I know is they are 19x8.5 and 19x10.5 with offsets somewhere in the +20s.
My rear calipers fit perfect and the front required a 5mm spacer in order to clear the caliper. So I would think with your smaller offset and wider wheels you will probably be fine, but I can't say for sure. |
Originally Posted by craig12895
(Post 10875234)
My rear calipers fit perfect and the front required a 5mm spacer in order to clear the caliper. So I would think with your smaller offset and wider wheels you will probably be fine, but I can't say for sure. I've seen a couple of 350z pictures on these forums that had the exact same spec wheel, and it looks real nice. But from what I could tell, they were on the Brembo brake setup. One I saw had a stoptech BBK, but those calipers might be a little bit smaller than the rather oversized Akebono ones. |
