315 tires
Old 04-24-2018, 05:37 PM
ss930350
ss930350's Avatar
Default 315 tires
I know maybe someone posted something similar, but I haven’t be able to find it. I'm thinking about buying stance sc8 20” staggered wheels, 265 front +35 and 315 rear +40. Will this fit on my Z without rubbing or fender rolling? Thanks for reading.
Old 04-24-2018, 06:30 PM
Bak3rme
Bak3rme's Avatar
u can fit anything with a lift kit.
Old 04-24-2018, 07:09 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,253 Likes on 2,314 Posts
No mention of width. And those offsets are way wrong for a Z.
"Standard" performance fit: 18 (or 19) x 9.5 Front and 18x10.5 Rear both with offsets between 15mm and 25mm. Tires to fit those 245/40-18 F 275/40-18 R OR... 255/285. (19s will use 35 aspect with those widths)
Now, that said, YES, you can fit wider wheels/tires. 305 out back is about the largest you'll see mentioned on a regular basis. 315 are maybe doable. But I'm 90% sure you won't fit 'em without at least a minimum of some type of fender work, rolling at minimum, overfenders/cutting at the other end. Going to depend on wheel width, offset and yes, inner fender and suspension clearances.
Also, that drastic of a tire width stagger, even if you get the diameters right, is going to lead to some questionable handling traits with a bias towards adding even more understeer to an already understeery pig.
So my next question: WHY? On the street, there's absolutely NO NEED for tires that large. No benefit beyond swag. Performance will even start to drop off once you get to a point of diminishing returns, usually somewhere right around 285 rears for several reasons: You're probably going to camber it way beyond practical to make it work AND you'll NEVER get those gumballs up to proper temps for any real performance work.
I advise you to root around the Tire&Wheel section some more to see what's what.
Try this link as well: https://www.google.com/search?q=fitt...nt=firefox-b-1
Old 04-24-2018, 08:00 PM
ss930350
ss930350's Avatar
yeah, the only reason I’m getting it is because it’s used and comes with Nitto Tires that wide, and it is 9.5 front 10.5 rear. Thank for the information! I think I might pass on threes wheel because of the offset
Old 04-25-2018, 06:13 PM
No_name
No_name's Avatar
...20”...front +35...315 rear +40. Will this...?
...think I might pass...
lgear080
South East Marketplace
04-23-2012 09:24 PM
sentry65
02-11-2005 06:31 AM
Quick Reply: 315 tires
