18x11 +15 all around?
Old 05-06-2018, 07:28 PM
Jzx100
Jzx100's Avatar
Default 18x11 +15 all around?
I bought my z 6 months ago coming from the Toyota platform i had two sc300 and a 5spd is300. The car is really fun to drive has a couple mods nismo stune exhuast plenum spacer higflow cats car sounds beautiful but im itching to get new wheels its on the stock track edition wheel...currently looking to get the rota mxr-r2 wanted to know if i could run 18x11 +15 or +20 all around didnt want to go 19s cuase i dont want to lose speed not sure if the car has a tune but it pulls hard.... for tires i was thinking 245 up front and 265 in rear or mabey 275 oh and im lowered on springs...
Old 05-06-2018, 09:23 PM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
18x11 is not worth it unless you are running a 285 or wider tire.
Old 05-07-2018, 07:04 AM
iideadeyeii
iideadeyeii's Avatar
245 on 11"
Old 05-07-2018, 08:47 AM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
Originally Posted by iideadeyeii
245 on 11"
was thinking the same thing ... I have 245s on my 18x8 daily wheels.
I wouldn't run 11" all around - a few reasons
#1 - it's too big of a foot print on the front end - I'd imagine your understeer would suck.
#2 - if you don't want to go 19" on the wheels bc the additional moment of inertia mass than going to a 18x11 is taking steps in the wrong direction for the same reason.
the OEM track wheels are 40-42lbs per wheel +/- accounting for the stagger(18-19lbs for the wheel and 22-24lbs for the tire)
A 18x11 wheel will probably be in the ~25lbs range. My 295 toyos are almost 31lbs - you're looking to go from 42lbs of rotational mass to 55lbs of rotational mass. That's a big jump.
If you are seriously considering selling your track wheels I may be interested in buying them. Send me a PM and we can talk.
Old 05-07-2018, 08:52 AM
JMII
JMII's Avatar
I run that combo on the stock 8" front and 8.5" rear Touring V2 wheels. 245 is a 9.6" tire, which is going to look a bit silly on 11" wheel. Hate the stretch / stance look but to each his own.
bealljk (05-07-2018)
Old 05-07-2018, 09:08 AM
travlee
Master
travlee's Avatar
Received 9,044 Likes on 6,510 Posts
op wants to be like this
which reminds me of this
Old 05-07-2018, 07:25 PM
Jzx100
Jzx100's Avatar
these are the wheels only hes running 11 in the rear and 10.5 up front +15 all around
Old 05-07-2018, 07:32 PM
Jzx100
Jzx100's Avatar
This guy is on varrestoen es6 11x19 all around +15 with a 245 tire these are the wheels i really wanted but there sold out contacted varrestoen they told me i had to wait 5 months before they get a new shipment
Old 05-07-2018, 07:49 PM
Jzx100
Jzx100's Avatar
http://stanceview.com/2016/10/11/noel_z33/
this the link the pics not showing for some reason
Old 05-07-2018, 09:00 PM
bealljk
bealljk's Avatar
Sounds like your mind is made up -
Is there anything that anyone on this forum can say that is going to persuade you away from putting a 245 tire on a 11" wheel? If not, just do it ...
If you like the performance aspect of your car now it'd be foolish to think those attributes will remain if you change your tire/wheel setup.
Old 05-07-2018, 09:59 PM
Jzx100
Jzx100's Avatar
no my mind is not made up based on tire size i just need help with fitment thats why i posted asking for advice this went from can i run 11s all around to an estimated tire size i might pick out wich
Old 05-07-2018, 11:14 PM
Jzx100
Jzx100's Avatar
No one has yet to really answerd my question everyones worked up over me mentioning 245....
Old 05-08-2018, 02:10 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,253 Likes on 2,314 Posts
No one is worked up about it, just that 245 is a totally unsuitable tire size for 11" wide wheels. There's a "rule" that one should follow and that is to apply a tire size that is at least as wide (tread width) as the wheel and not to exceed 120% else performance drops off. Likewise, not a good idea to go below 100% of the wheel width but can do so down to about 90% without too much performance offset.
Yes, one can mount a tire that is outside of this range. But it doesn't make it right.
S'far as running 11" all around, well, it's been said already, you run the risk of creating more understeer (if you size the front tire correctly) in an already understeering pig. Not a major issue that can't be overcome with proper suspension tuning.
Will they fit? Depends on tire size and offset. I'm going to GUESS that +15mm 11's are going to scrub the fenders at lock but do not know for sure. That's with the proper tires (for the wheels), say, a 285. 245s stretched will probably fit up front without interference but that's the point, no performance gain stretching the tire to make it fit. FWIW, I see a lot running 10.5 square with 275s, if that helps.
To your comment about 19's and losing speed.... 19s by themselves are not the enemy. It all depends on the overall weight of the tire/wheel combination. My S-Tune 19x9/10 wheels weigh 20.4lbs each on average and with the tires I currently have on them, the full weights are in the mid-40s. If you compare that to any 18" replica wheel/tire combination (as you've shown with the Work copies), you can bet mine are wayyyyyy underweight. Only combinations I've run on my car that were as light were 18" RPF1s and Track V.1s.
Yeah yeah, someone will bring up inertial/centrifugal effect of the spinning wheel with mass farther from center. Blah blah blah, if one can feel that difference and point it squarely at and quantify it from the rim being further from center, I say more power to you, go buy 15s then. There is some effect upon wheel deflection but nothing you can feel unless maybe you're on track. For the street, psh, I stick by my 19s.
bealljk (05-08-2018)
Old 05-08-2018, 06:26 AM
bealljk
bealljk's Avatar
Originally Posted by MicVelo
Blah blah blah
When I went from to 20" wheels I could feel the loss in acceleration ... I seriously thought something was wrong with my tune.
but...all good points ... jealous of your 20lb 19s
Old 05-08-2018, 05:30 PM
Spike100
Spike100's Avatar
Old 05-08-2018, 07:42 PM
Jzx100
Jzx100's Avatar
Thank for all your help.....
Old 05-08-2018, 08:26 PM
mr. sparco
mr. sparco's Avatar
Its a mild aggressive setup. I have 19x10F/11R +10 on 275/35, has a bit of poke but nothing over the top. I'm not slammed or have excessive camber. Fronts will poke out too much on x11 +15 IMO.
Old 05-11-2018, 03:21 PM
Desert Z
Desert Z's Avatar
OP just wants to be the coolest kid in his class. Understandable.
Old 05-11-2018, 06:59 PM
bealljk
bealljk's Avatar
at the junior college...
Old 05-13-2018, 04:42 PM
Jzx100
Jzx100's Avatar
Im not in college i just never bought wheels for a car..... every car i bought always had really nice wheels even the track wheels are nice i get compliments everyday until i tell them its factory wheels and they loooked shoocked.... not the 08 track the 04.... my car is really simple but awesome all i want is an aggressive fitment and retain my speed.......
Quick Reply: 18x11 +15 all around?
