20 fit and tire help
on
I am debating on getting new wheels and the ones I want the most only come in 20s.
Im not sure about fit and was hoping someone might be able to help.
I was was looking at 20x9 in the front and 20x10 in the back. I have the choice of ET 25 or 35 in front and 25 or 40 in the back.
Any my idea on if any of these options would work and if so whats a good tire size?
thanks in advance.
thanks in advance.
350Z/370Z Tech Moderator
thanks in advance.
thanks in advance.
225 45% 18 25.97 Stock Reference Size
245 45% 18 26.68 Stock Reference Size
Alts:
255 30% 20 26.02
275 30% 20 26.50
Find it amusing that it's such a hard concept .... Section widths are pretty much constant (+/-10mm) for Z33; and aspect ratios drop 5% with each inch in wheel diameter increase.
Same with offsets.... for 8.5/9/9.5 and 9.5/10/10.5, the offsets the car likes will always be somewhere between +15 on the lower widths and up to +25 on the wider widths. NEVER higher than stock unless you're gonna run 11s or 12s and trying to keep 'em under stock fenders.
Now about going 20s...... WHY?
d!abolic
12-26-2008 06:04 PM
nooooorb
11-24-2006 05:40 AM
