Wheel fitment question
Hey guys new to this forum thing. Figured the best place to get advice about this would be from other z owners. I’m looking into buying wheels for my 04 350z and don’t know what specs will fit best. The specs options for the wheels I want are 17x8 +0 (probably not getting it but throwing out there anyway) 17x8.5 -6 17x9 -13 17x9.5 -19 im on stock suspension now but will be getting coil overs in the future. I would much rather run the most aggressive spec all around but don’t mind staggering. If it could fit all around or if you Any opinions on what specs to get for best fitment it’d be much appreciated. Haven’t a clue what tires to run either so input on that would also be greatly appreciated. |
Lots of folks go to F18 X 9.5 +15, RR 18 X 10.5 +15 for street use. 1000s of posts to read here, do a little search work!
Is there any particular reason behind running 17s?
Originally Posted by @deathwya
(Post 10975558)
Hey guys new to this forum thing. Figured the best place to get advice about this would be from other z owners. I’m looking into buying wheels for my 04 350z and don’t know what specs will fit best. The specs options for the wheels I want are 17x8 +0 (probably not getting it but throwing out there anyway) 17x8.5 -6 17x9 -13 17x9.5 -19 im on stock suspension now but will be getting coil overs in the future. I would much rather run the most aggressive spec all around but don’t mind staggering. If it could fit all around or if you Any opinions on what specs to get for best fitment it’d be much appreciated. Haven’t a clue what tires to run either so input on that would also be greatly appreciated. No clue where those fitments are coming from but if you look carefully, as your widths go wider, so are your offsets, pushing the wheels that much further out. (Case in point: your hypothetical 17x9.5 -19 pushes the wheel out 2.5" (61mm). Clearance issues are highly probable. But if you have the room (you don't), no problem with that but while the offsets are aggressive, the wheel widths (and proper tire sizing to fit; being the more important part for true handling improvements) are pretty non-aggressive because you're limiting the tire sizes you can put underneath. Your widest, 9.5" hypothetical wheel, is about the STARTING POINT for real rubber. You don't mention tire sizes and I'm going to say you're limiting your tire choices with "tiny" 17s. About the widest you're going to go on 17x9.5s before running into tire diameter issues is a 235/50-17, maybe a 245/45-17 but then, tire selection is limited. As pointed out above, 18s are your best bet for proper fitment with "real" (that is, better selection of sizes and brands of) tires. Case in point: there are 7 performance tires in the 17" (245/45-17) cited. Conversely, there are 63 selections in 18" sizes. (Quick search for 245/45-17 and 255/40-18s on Tire Rack). As mentioned, do more research in the Tire/Wheel section. Study pics and what others are running. You'll find that the suggestion above by jhc is about the most popular set up you're going to find. You can get more aggressive but figure on body mods (lip rolling at least) going more aggressive than +15 offsets, particularly where lowering. If you're going to do a full set of wheels and tires, might as well start with a known working setup. |
(Post 10975617)
Originally Posted by MicVelo
(Post 10975619)
^^^ What JHC said above (and what Heel is hinting at). Here's why...
(Post 10975635)
thank you for the input !! The reason the wheels are 17s is because they’re watanabe RS and watanabe almost exclusively make 16 and below diameter except for the R17 I want to use. The wheel specs I got from the dealer that orders through watanabe directly and were the only 4 available to purchase on their website. I understand the points you guys are making and will be do more research thanks again We're talkin' ultra light wheels here folks. My 15x8s were ~12#... Would love to see a set of them on a 33 just for that throwback look! |
(Post 10975642)
https://cimg2.ibsrv.net/gimg/my350z....f868781d23.jpg Assuming google translate hasn't mucked up the numbers, I believe the specs are 17 x 7 +30 with 225/50/17 up front and 235/50/17 in the rear, which is pretty conservative. |
(Post 10975695)
Check it out, Mic! It's also in your favorite color ;)
https://cimg2.ibsrv.net/gimg/my350z....f868781d23.jpg Assuming google translate hasn't mucked up the numbers, I believe the specs are 17 x 7 +30 with 225/50/17 up front and 235/50/17 in the rear, which is pretty conservative. Ummm, thanks, D, but no thanks. If they were in the proper size, maybe. Guess I'll be sticking with my existing cache of rollers. Hahahahaha. |
