Perfect size??
Hello forum. I’ve got an 06 and I’m about to buy new wheels and tires. I’m looking to do an 18x10.5 square but I’m wanting to do a deep style wheel. I was thinking Aodhan 03 or one of the deeper XXR’s. What would be a higher moderate aggressive looking size tire to run? I’m on lowering springs but plan to move to coilovers. Also, I don’t have 3k to spend on wheels & tires. I’m thinking about a total of 1500 (give or take a little bit) for everything. I know there’s a few decent set ups on that kind of budget. |
06 hr huh....
Originally Posted by travlee
(Post 10982030)
06 hr huh....
Lets not be lazy and try searching...car has been out for 16 years, try looking in the stretched/aggressive wheel sub forum
(Post 10982032)
Hey actually why are you even on a forum if you’re just an unwilling dick? |
Awwww, someone is triggered
You’re beyond toxic so I’m gunna exit and let you get back to your stuff |
I Like how you stealth edited your original post
Did you bother searching at all? Your answers are literally on the first page of the wheel/tire section...
https://my350z.com/forum/wheels-and-...s-welcome.html https://my350z.com/forum/wheels-and-...es-thread.html Those should get you started. |
Originally Posted by bboypuertoroc
(Post 10982050)
https://my350z.com/forum/wheels-and-...s-welcome.html https://my350z.com/forum/wheels-and-...es-thread.html Those should get you started. I am at work so I don’t have time to go reading through forums like that. I figured I’d post and check periodically till I CAN in depth look on here. So far the Z community seems just out right rude and unwilling to just be helpful without some sort of attitude lmao. |
There's nothing "simple" about your question. We don't know how low your car is, what offset wheels you're looking at, wtf "higher moderate aggressive" means relative to tire size, etc.
I already spoon fed you the answer. Do your research. |
It is pretty simple. With the information I gave you going 10.5 wide on an 18inch wheel, you simply state what size tires would have a higher moderate aggressive look. (High in the moderate range) i feel like you and the other dude are just out trying to fulfil your daily ego-meters. |
And you don’t know how tire size has anything to do with an aggressive look?! 😂😂😂😂 |
OP is lazy as hell
(Post 10982074)
OP is lazy as hell
Oh yeah....and you are still lazy
Originally Posted by Thirteengraves
(Post 10982067)
And you don’t know how tire size has anything to do with an aggressive look?! 😂😂😂😂 AGAIN, I helped you help yourself. You can do the rest on your own. |
If you run anything narrower than a 295 on a 10.5" rim, you might wanna invest in a steamer for all that rice.
(Post 10982066)
It is pretty simple. With the information I gave you going 10.5 wide on an 18inch wheel, you simply state what size tires would have a higher moderate aggressive look. (High in the moderate range) i feel like you and the other dude are just out trying to fulfil your daily ego-meters. If you look in the tire/wheel section, you'd easily see that 10.5 wheels are pretty much the standard in upgraded Z wheels and they wear 275 to 295s with not too much trouble DEPENDING ON WHEEL OFFSET. And no one knows this from your description, which is what they were getting at... not enough information. |
