spacers for flush fit on completely stock 2008 350z
https://cimg5.ibsrv.net/gimg/my350z....bcadcf60a8.jpg
https://cimg9.ibsrv.net/gimg/my350z....bb789b3c89.jpg Hey guys, I have a completely stock 2008 Nissan 350z touring trim. I have stock wheels, I'd like to upgrade to rpf1s in the future but right now I don't have $2000 to spend. In the mean time I'd like to have my wheels flush with the quarter panels. I'm not quite sure how big of a spacer I should run, I want hub-centric spacers (the ones that have studs on them) I don't want to rub at all and I don't want to roll my fenders. I just don't want my Z to look like I have a widebody kit with small wheels. It looks a bit goofy. Can you guys help me? Front 225/45/18 Rear 245/45/18 |
25MM front, 30MM rear |
I edited my post to show you what it looks like.
Hey, just wandering, do you have any pictures or links to what it would look like with those spacers installed? thanks for replying btw.
Originally Posted by Jdm.350z
(Post 10986187)
Right after that question I typed that into Google and found plenty, I just have bad experience with Google and feel better talking to actual people. Thanks by the way even though I feel stupid now. 😂
20mm and 25mm is one of the common ones |
That's what I was thinking after doing some research cause I don't wanna rub when I upgrade to coilovers. I dont know if I'm going to get wheels or coilovers first, so i may just go with 20mm front and 25mm rear just to keep it looking uneven. I was also researching about how 30mm rear rub if lowered. I'm on stock suspension so it wouldn't matter now. I don't wanna buy 30mm just to have to buy 25mm in the future if I buy coilovers first.
Just for reference, here's my '05 with the same wheels sitting on stock suspension with 20mm spacers in the front and 25mm in the rear.
https://cimg3.ibsrv.net/gimg/my350z....813eb8f350.jpg https://cimg7.ibsrv.net/gimg/my350z....b56cecdf40.jpg |
Make sure to order the appropriate lugs if you go over 10mm. (Obviously)
https://my350z.com/forum/wheels-and-tires/426285-faq-official-wheel-spacer-thread.html
That setup 25mm front and 30mm rear is right on the money that's the setup I'm running now handles like a dream as well get you a really good set from b2autodesigns.com you can Thank me later!
Did you at any point have paranoia with running spacers? I have a set of new 30mm H&R track spacers but yet to install..
Originally Posted by kham25
(Post 10986476)
(Post 10986482)
I didn't, but I only had them on for about a year before I moved on to a different set of wheels with no spacers. I used the bolt-on hubcentric spacers from Z1. Just make sure you torque everything down to spec and you should be fine. Re-check them after putting some miles on them. If you want some added piece of mind, you can always put on some red threadlocker loctite.
Did you purchase new lugs or did you use the stock lug nuts? |
(Post 10986487)
Thank you for your advice... Did you purchase new lugs or did you use the stock lug nuts? I don't see why the stock lug nuts could not be used though. I don't believe the Z1 spacer studs were longer than OEM stud length. |
(Post 10986508)
I was using some aftermarket lug nuts at the time. I believe they were open ended Muteki SR48 lug nuts.
(Post 10986207)
