HELP!!! My 350Z is lowered and I want 19's
Hello,
I have a 03 Performance model with stock 18" rims. I recently had the car lowered approximately 1". I had some 19's put on at Tire Discounters and noticed the very out of whack alignment. I know that I need a new traction rod or camber adjuster, all I've been able to find are rear camber adjusters. Are there front camber / caster adjusters out there? And if so could you give me some brandnames or websites. If there are no front adjusters out there should I just have my original springs put back on? Thanks Tim |
tim,
you should be able to adjust the camber for the rear. If anything the front will have some slight camber, but the toe can be adjusted. you can spend the money on 350evo's A-arm replacement but it's kind of pricey. I would just be diligent about rotating your tires side to side to get optimal wear. -Jeff |
| All times are GMT -8. The time now is 02:16 PM. |
