Toyo Proxes 4 OR Eagle F1 GS D3's?
Hey guys, Im about to switch the fronts out with some 245/40/18's...Im stuck between the F1's and the Proxes 4's. Found an interesting deal on Ebay for the Toyo's....:http://cgi.ebay.com/ebaymotors/ws/eB...category=66476
Which of the two tires do you recommend. Is this a good deal on the Toyo's? ^^ |
Tires
Hi AceJ587
I would highly recomend the Toyo T1-S Tires. I just installed these tires on my Z and they are much better than stock. I am running 245/40/18 on the front and 275/40/18 on the rear. These tires are supposed to be 2lbs lighter each than stock. Newer high tech compounds and much stiffer for better cornering. I just tested them in the local hills and they are awsome! Fronts run about 190.00 ea installed and rears run 230.00 ea installed. Hope this helps. |
Between these 2 tires, I would go with the F1GS-D3. The Toyo Proxes 4 is in the 'Ultra High Performance All Season' category, while the Goodyear is in the 'Max Performance Summer' category. This means that the Goodyear is more of a no-compromise performance tire than this particular Toyo.
The Toyo model to consider here would be the T1-S in comparison to the Goodyear, not the Proxes 4. Good luck! |
Thanks guys..I got a good deal on two F1's, going with those.;)
| All times are GMT -8. The time now is 10:53 AM. |
