MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Wheels & Tires (https://my350z.com/forum/wheels-and-tires-60/)
-   -   Sqeeking AP's (https://my350z.com/forum/wheels-and-tires/92909-sqeeking-aps.html)
Barzten1 Sep 24, 2004 02:33 AM
Sqeeking AP's
1 Attachment(s)
Had the 13'' AP Racing brake kit installed a few weeks back and haven't had a day go by without them sqeeking. I love the way the kit looks and performs but the sqeeking is annoying. Do all brake upgrades do that?
tranzholik Sep 24, 2004 08:44 AM
Re: Sqeeking AP's
does it sqeak after proper bedding??
apex locator Sep 24, 2004 10:15 AM
try bedding them in again and/or using some anti-squeel
btw, yor nismo logo is crooked:p
Barzten1 Sep 24, 2004 12:00 PM
whats proper bedding
S12 driver Sep 25, 2004 04:04 AM
Usually you run the car up to 45mph or so then do 8-10 slow stops, then 3-4 hard stops. After that you let the brakes cool for 30 min - 24 hrs.
Barzten1 Sep 25, 2004 04:12 AM
Ive had the brakes on for about 6 weeks or so. Whats the next step?
Mikey996 Sep 25, 2004 11:11 AM
Stoptech recommends a different procedure to bed the brakes then, for example, what is says on the box of hps brake pads. With street performance pads, which most of us have, they say to do series of 10 decelerations from 60mph to 5-10mph using 80 to 90% braking force, assuming 100% would be engaging the abs. So thats pretty hard braking.
So basically you'd accelerate to 60mph, brake hard down to 5 to 10mph, then accelerate back up to 60, brake again and do it 10 times. Then drive around, trying to stay off the brakes, allowing them to cool and then repeat the whole procedure for another series of 10 decelerations. You can find all of this and more detail on it on stoptechs website.
If your brakes are 6 weeks old you can try cleaning the rotors with some soap and water and brake cleaner first, shave the pads down slightly and then try the bedding procedure again. I believe somebody else on this board tried that. Not sure how it worked for him.
infinit Sep 27, 2004 11:27 AM
APs are notorious for squeeking.
mchapman Sep 29, 2004 04:07 AM
Re: Sqeeking AP's
If the pads are quieter when they are warmed up then it sounds like its just the pads that are the cause of the noise not your big brake kit. If you get pads with a lower metal compound then they shouldnt squeek as much. This is why stock pads dont squeek but you can get good performance pads that are alot better than stock that dont squeek.
