Check Engine Light After Cams Install
Old Oct 15, 2006 | 05:32 PM
ZPirate's Avatar
ZPirate
Default Check Engine Light After Cams Install
I had Nismo cams installed in my car about three weeks ago. Other than having a rough idle my car has run fine since the install. I was planning on having the idle bumped to 850 or 900 rpm this week to hopefully fix the problem of the engine bogging down to 600 rpm on occassion at idle.
On Saturday I got up to drive the car to a local car show. After I started the car and let it warm up for a couple of minutes the check engine light came on. It was cool Saturday morning, in the low 40s. It hasn't been that cool yet this Fall. It stayed on while I drove to and from the show. I checked everything I could think of but couldn't find the problem. Today I started the car again and the light came on again. Anyone else had this problem? I have the Technosquare ECU reflash and most NA bolt on mods.
I was wondering if it might be one of the sensors in the cats or headers. I had one of the sensors in the cats work its way loose before, but it didn't trigger the check engine light. It caused a rattling sound so I took it to my dealer who put it on the lift and found the problem.
I am beginning to wonder if I don't need to get my ECU reflashed again, although my dealer and Technosquare have both told me that I shouldn't have to. I am going to call my dealer tomorrow about getting the car in to have it checked out on the computer.
Old Oct 15, 2006 | 05:39 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You're going to have to check the code... try autozone or an equivalent shop that will check the code for free.
No way to diagnose the problem without doing this
Old Oct 15, 2006 | 05:54 PM
ZPirate's Avatar
ZPirate
My other question is it safe to drive it 30 miles to my dealer?
Old Oct 15, 2006 | 06:05 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
find a local Autozone as suggested and get it scanned...so when you go to the dealer you know what to tell them
Old Oct 16, 2006 | 06:50 AM
Q45tech's Avatar
Q45tech
Every person should OWN their own OBD2 scanner............so inexpensive.
Old Oct 16, 2006 | 08:32 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
or even better, Cipher
Old Oct 16, 2006 | 10:24 AM
Racerbmx87's Avatar
Racerbmx87
yep, i wish i had a Cipher
Old Oct 16, 2006 | 02:40 PM
ZPirate's Avatar
ZPirate
Just got back from my dealer. The check engine light was caused by a sensor detecting that the car was running too lean. They reset it and bumped my idle up to 900 rpm. Since the check engine light came on while the car was idling they hope bumping the idle will fix the problem. If not I may have to get my ECU reflashed again. It seems to be running fine now.
Old Oct 16, 2006 | 06:01 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Good news. A cipher would be a good investment for you, if you get the CEL again. If not, then you should be good
Old Oct 17, 2006 | 04:55 AM
ZPirate's Avatar
ZPirate
Where's the best place to get a Cipher? I am not really familar with it. Does it allow you to make adjustments to the ECU?
Old Oct 17, 2006 | 08:17 AM
EM-EFER's Avatar
EM-EFER
AAM
Old Oct 17, 2006 | 08:30 AM
mario60185's Avatar
mario60185
Chicago Realtor
If you have cams and all the basic bolt ons I think its time for a utec. Get that thing tuned to perfection. How do you like the cams by the way?
Old Oct 17, 2006 | 08:32 AM
IIQuickSilverII's Avatar
IIQuickSilverII
defiantly... you need an ECU if you have cams... plus its a must to raise the idle to circa 850 rpms with cams too
Old Oct 17, 2006 | 09:30 AM
ZPirate's Avatar
ZPirate
I have the Technosquare ECU reflash. I had it done just before I got my last bolt on mod, the headers, to include them. I was told by Technosquare that I wouldn't need another reflash if I got cams. I wonder if I don't need some fine tuning now though.
I really like the cams, except for the idle issues I have had. They really bring out the power above 3000 rpm up to the rev limiter. After I got my 3.9 gears I noticed that power seemed to drop off quickly above 5800 rpm. Now it pulls hard all the way. There are several cams out there that are more aggressive than the Nismos, but I wanted something reliable and something that didn't make the car hard to drive on the street.
ZPirate's Avatar
ZPirate
Just had my idle raised to 900 rpm. It seems to make a difference.
Old Oct 17, 2006 | 09:49 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The reason having the cipher tool is useful... is that you can do a lot of air/fuel checking, troubleshooting, etc.
You can plot your AFR and timing versus RPM and see how the technosquare reflash is holding up. Just for example.
If you race, you can see where you are shifting, as well as intake/coolant temps.
Overall, it's a really great tool...for the serious enthusiast it's a must IMO
Old Oct 17, 2006 | 11:01 AM
97supratt's Avatar
97supratt
+1
Old Nov 19, 2006 | 05:22 AM
SmokerZ's Avatar
SmokerZ
I Like Everyone
How do you reset the Check Engine Light?
Old Nov 19, 2006 | 04:18 PM
undrgnd's Avatar
undrgnd
You can reset the CEL? Wow! I've been driving around with it on for several months; I thought it was on forever once set...
Old Nov 19, 2006 | 04:29 PM
ObiRedKenobi's Avatar
ObiRedKenobi
I just unplug the battery for a bit and it resets it. Probably a better way but its always worked for me.
