06-08 Gloss Black Painted Headlight Blistering Problem!
Old Apr 23, 2012 | 06:42 PM
FliPPER_Z's Avatar
FliPPER_Z
Default 06-08 Gloss Black Painted Headlight Blistering Problem!
Im sure im not the only one with this problem...I got a pair of 06-08 modified headlights with paint bubbling/blister problems right below the projector lens. According to some threads this may be because of the ballasts getting too hot however it's just an assumption and not a fact. The ballasts sits about 1 inch below this piece of plastic/bezel, i dont think it the ballast can cause that. Could it be the type of paint or maybe the surface wasn't prep enough? Here is a pic
Any suggestions ?
Old Apr 23, 2012 | 06:44 PM
bmccann101's Avatar
bmccann101
i talked w casear about this on mine, we left them painted silver like the proj housing as it seems to only happen to dark colored paint, but its simply heat from the magnified headlight beam coming off that lens.. hes had the same issues, unless you use engine super high temp paint on that, youll end up warrantying normal autobody paint like that often..
its not from underneath, its the same idea as frying an ant man. maybe they make a high temp clear? not sure...
Old Apr 23, 2012 | 06:58 PM
FliPPER_Z's Avatar
FliPPER_Z
Yeah, I actually thought about that.. Maybe the car was parked in a certain angle with direct sun exposure and the magnified heat burned right through. I took the headlight apart already, the plastic underneath is completely cooked and deformed .
Another theory could be a combination of the HID and STI Clear Lens.. I imagine the light is more intense than the stock ripple lens.
It cant be the color because I got another white headlight with the same problem.
Old Apr 23, 2012 | 07:16 PM
bmccann101's Avatar
bmccann101
yep happens when you use that new sti-r lens. Leaving that one single area chrome helps.
Old Apr 23, 2012 | 08:32 PM
FliPPER_Z's Avatar
FliPPER_Z
more pics..
Old Apr 24, 2012 | 10:01 AM
User 42426's Avatar
User 42426
are you going to do anything about it? Or are you just asking how that happened? Its from the heat
Old Apr 24, 2012 | 12:13 PM
FliPPER_Z's Avatar
FliPPER_Z
I actually wanna figure out how we can avoid this..but im afraid there's nothing we can do about this.
I soda blasted most of the black paint and used grey putty to fill the small holes left behind..
repainted the pieces using matte black paint.
Old May 14, 2012 | 09:58 AM
Jackson0927's Avatar
Jackson0927
so any1 know if you use high temp engine paint will it do the same. stuff rated to like 600 degrees...or is it the chrome bubbling under the paint?
Uriyo_
Sep 8, 2021 08:46 AM
