Official Forced Induction Engine Oil Thread
Old Feb 26, 2007 | 07:43 AM
MIAPLAYA's Avatar
MIAPLAYA
Default Official Forced Induction Engine Oil Thread
Mods please stick:
Starting a thread to consolidate all the varying posts about what oil everyone is running. Please only post the oil you use if it is not already here. If you use something that already has a post for it please don't post again unless its to add some factual data such as an oil analysis of what you are using or some data sheets on it if they aren't already here. If a mod could update each oil brand's post with any new data that I mentioned when its posted we can keep this clean. I'll start it off.
Brand: Turbonetics TS-1
Weight: 5W-30
Type: Full Synthetic
Cost: $46 / 6 quarts
Viscosity Index: 175
Flash Point: above 450°F
Data Sheet for Turbonetics TS-1: http://turboneticsownersclub.com/turbos/ts1.pdf
Oil Filter used with this oil: Nissan Factory Oil Filter (P/N: 15208)
Oil analysis from a 350Z using Turbonetics TS-1 oil for 13k boosted miles attached.
Old Feb 26, 2007 | 07:50 AM
Alberto's Avatar
Alberto
Cranky FI Owner
A suggestion if I may-can you also post what oil filter you are using? Good thread, Im getting ready to send an oil sample out to Blackstone labs myself.
Old Feb 26, 2007 | 07:51 AM
MIAPLAYA's Avatar
MIAPLAYA
Good call... I'll add that to my original post..
Old Feb 26, 2007 | 08:03 AM
tig488's Avatar
tig488
Mobil1 10W-30, ~$25/5qt, i use the Mobil1 filter.
Old Feb 26, 2007 | 08:12 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Brand: Motul 300V
Weight: 15w50
Type: 100% Ester Synthetic
Cost: $75 for 6 Liters(comes in 2L containers)
Viscosity Index: Unknown
Flash Point: Unknown
Fact Sheet: http://www.motul.com.ph/product_line...4stroke02.html
General information:
The ASTM D 4741 official test of HT/HS* (High Temperature High Shear) viscosity measures the viscosity of lubricants at very high temperature (150°C/ 302°F) and shear (1 000 000 s-1). This test is considered to be a good model of the fluid's state when exposed to extreme shear and temperature as found in an engine.
The higher the benchmark, the best the oil film keeps up its viscosity, hence its resistance to high stress in hydrodynamic rating. Tests prove the best results are achieved with a high viscosity grade (50 or 60) at high
temperature, and without viscosity boosters.
- Resistance to high temperature coking
While racing, when the engine is pushed to the extreme, or during pit stops and refuellings, the oil temperature reaches maximal values.
Same happens to usual cars when stuck in traffic jams, hard or fast-driven for long journeys, or stopped at busy toll-gates.
Hence the capital attention to avoid the carbonization of lubricants heated to high temperatures.The lubricant residues carbonized through overheating (i.e.
charring) are weighed, the best benchmark being a low weight.
The test measures the coking of engine oils at a sustained high temperature (5 days at 160°C / 320°F) and blasted for 48 hours against an aluminum shim
heated at 290°C / 554°F.
Tests prove the choice of base-stocks, especially synthetic ester bases, to be a major promoter of resistance to high temperature coking.
The 300V's of the MOTORSPORT line reveal virtually almost no coking during this test.
Old Feb 26, 2007 | 08:14 AM
MIAPLAYA's Avatar
MIAPLAYA
Put into same format:
Brand: Mobil 1
Weight: 10W-30
Cost: $25 / 5 quarts
Viscosity Index: unknown
Flash point: unknown
Oil Filter used with this oil: Mobil 1 Oil filter (P/N: M1-108)
Old Feb 26, 2007 | 08:16 AM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Sharif@Forged
Motul 300V 15w-50 with Nissan OEM oil filter
I'll try to get an oil analysis done on the next change.
Brand: Motul 300V
Weight: 15W-50
Cost: $25.90 / 2 Liters
Old Feb 26, 2007 | 08:38 AM
tig488's Avatar
tig488
Brand: Mobil 1
Weight: 10W-30
why when you will do it for me
you can also use hte M1-110 filter iirc, its longer.
Old Feb 26, 2007 | 08:43 AM
MIAPLAYA's Avatar
MIAPLAYA
LOL I wasn't asking you to do it just telling you I did...
Old Feb 26, 2007 | 11:19 AM
QuadCam's Avatar
QuadCam
Brand: Motul 8100
Weight: 5W-40
Cost: $36 / 5Liter
Viscosity Index: 173
Flash point: 442*F
Oil Filter used with this oil: Purolator Pure One Filter (PL14612)
Old Feb 26, 2007 | 11:37 AM
maximumsportZ's Avatar
maximumsportZ
Turbo System: APS TT
Brand: Amsoil
Weight: 10W-40
Type: High Performance Synthetic
Cost: $35 / 6qts.
Viscosity Index: 178
Flash Point: above 446°F
AMSOIL Synthetic 10W-40 Premium Protection Motor Oil is a high viscosity oil engineered to protect against metal-to-metal contact. It resists viscosity shear and is formulated with a heavy treatment of anti-wear additives for excellent protection of gears, bearings, cam lobes and other high-pressure components in engines and transmissions. AMSOIL Premium Protection Synthetic Motor Oil helps extend engine life.
Old Feb 26, 2007 | 12:13 PM
tonyrd1's Avatar
tonyrd1
Brand: Mobil 1
Weight: 15W-50
Cost: $35/ 5qts
Old Feb 26, 2007 | 05:49 PM
al v's Avatar
al v
Brand: Liqui Moly
Weight: 10W-60
Type: Synthoil Race tech GT1 Full Synthetic
Cost: $99/ 5qts
Old Feb 26, 2007 | 05:56 PM
toast's Avatar
toast
Brand: Motul 8100
Weight: 5W-40
Cost: $36 / 5Liter
Flash point: 442*F
Oil Filter used with this oil: K&N Filter (HP-1008)
Old Feb 26, 2007 | 06:04 PM
Mike Wazowski's Avatar
Mike Wazowski
Brand: Royal Purple XPR
Weight: 10W-40
Cost: $7.00 / 1qt.
Flash Point: unknown
Old Feb 26, 2007 | 06:15 PM
TheProfessional's Avatar
TheProfessional
Brand: Royal Purple
Weight: 10W-30
Cost: $6.58 Qt
Viscosity Index: 156
Flash point: 385*F
Most recent oil analysis submitted 1/29/07 with 7,350mi change interval (1qt added at 5,000mi).
Attached Thumbnails Official Forced Induction Engine Oil Thread-020507-20blackstone-20results.jpg
Old Feb 26, 2007 | 06:19 PM
Jay'Z's Avatar
Jay'Z
Brand: RP
Weight: 20W-50
Cost: $7.50 / Per Quart
Viscosity Index: 149
Flash point: 400*F
Oil Filter used with this oil: K&N (HP1008)
http://www.longrider.com/longriderrpmoips.pdf
Old Feb 26, 2007 | 07:54 PM
Cannysage's Avatar
Cannysage
Brand: Mobile 1
Weight: 10W-40
Type: Synthetic
Cost: $2.11 Qt or so at walmart
Oil Filter: mobile 1
Old Feb 26, 2007 | 08:56 PM
thawk408's Avatar
thawk408
Originally Posted by Cannysage
Brand: Mobile 1
Weight: 10W-40
Type: Synthetic
Is this the highmilage oil? Becuase on Mobil's site they dont show any 10w-40 except the highmilage blend.
Old Feb 26, 2007 | 09:36 PM
Cannysage's Avatar
Cannysage
dunno, but you can get it at walmart, lol.. definitely not the best, but won't be too bad with the spring/summer coming up. you'd never want to go 'high mileage' with any kind of oil with FI.
