370z headers ----> HR 350z?
Old Jan 9, 2011 | 07:12 PM
07_350z_JP's Avatar
07_350z_JP
Default 370z headers ----> HR 350z?
i know the test pipes/hfc from 370z are same fitment/interchange with HR 350z. Question is what about the aftermarket headers. Stillen site lists the same part # for HR 350z and 370z so the "should" be direct bolt ons right?
Old Jan 10, 2011 | 07:07 AM
archangel72's Avatar
archangel72
It should be, can't find it but they is a guy on this board that put the oem 370z headers right on his hr, no prob.
Old Jan 11, 2011 | 12:32 PM
scardeal's Avatar
scardeal
Quick Q: Are the OEM 370z headers any better than the 350Z HR headers?
Old Jan 12, 2011 | 09:16 AM
uglyduc's Avatar
uglyduc
I think it's crazy people work so hard to make their car perform worse.
Old Jan 12, 2011 | 01:00 PM
Cali-Darkness's Avatar
Cali-Darkness
I think you mean the 350Z (VQ35HR) test pipes/HFC fit the 370Z... They were made for the HR and then people figured out they were interchangeable.
Please explain your logic/knowledge behind your comment.
Old Jan 12, 2011 | 03:48 PM
uglyduc's Avatar
uglyduc
Following the logic of installing OEM 370 headers on 350 = gains makes no sense to me. At best you'll be sitting par after all that work. Unless you're missing 350 HR headers and only have a set of 370 headers laying around, it's a waste. Just because the headers are off a slightly larger displacement engine doesn't mean they are better for your application.
I am of the opinion that OEM headers are better than most aftermarket pipes for our applications and this is coming from someone with a set of Stillen headers/HFC's installed.
Just my .02.
Old Jan 12, 2011 | 05:01 PM
Cali-Darkness
Ahhhhh, I see what you mean now. I thought you were talking in general, mod wise.
I would like to see the 370Z exhaust manifolds/headers next to the 07-08 350Z exhaust manifolds/headers. I wonder how they compare in size & design.
Old Jan 14, 2011 | 03:01 AM
kd07z's Avatar
kd07z
The engine in the 370z sits lower then in the 350z. The headers and/or the cats are longer on the 350z then the 370z because of the lower engine fitment.
Old Mar 30, 2012 | 03:37 PM
Erwin06Z's Avatar
Erwin06Z
They also fit the DE and are available with heat shields for 300.
Old Mar 30, 2012 | 03:48 PM
Erwin06Z's Avatar
Erwin06Z
Just my .02.
Well then you obviously have little to no real experience with dyno tuning various set ups with and without aftermarket exhausts and headers. It is a fact that the equal length tubular headers on the 370 flow better than those on the 35DE/HR, (more so DE) despite what you have on your car. When it comes to the 1/4 mile the extra 3-5hp and 2lbs of TQ give or take over stock manifolds here and there while tuning add up.
Old Mar 30, 2012 | 03:56 PM
Erwin06Z's Avatar
Erwin06Z
Not the HR comparison you asked for but will help anyone with a DE that's curious.
http://i.ebayimg.com/t/VQ35DE-OEM-Ex...,!9Mw~~_12.JPG
DE http://www.z1motorsports.com/350_g35...309&imageNum=1
Old Mar 30, 2012 | 04:08 PM
Erwin06Z's Avatar
Erwin06Z
Just because yours does.
Old Apr 17, 2012 | 08:06 AM
Tko's Avatar
Tko
I just bought (for nearly nothing) a set of stock 370z exhaust manifolds. I am going to install them on my de 350z I have test pipes and figure I can just cut and re weld them to fit. I understand my gains will be little to none but honestly don't care, its part of my finishing touches. When I get them Ill take some pics, in the mean time if you look at the
stock de mani's
Compared to the stock 370 manifolds
Then Nismo 350z R tune headers
You can see that I hope for good mid power gains.
Old Apr 17, 2012 | 10:46 AM
denchan350gt's Avatar
denchan350gt
I think the head flange is different between a DE and HR,370z. I think a stud has to be modified.
Old Apr 17, 2012 | 11:31 AM
Tko's Avatar
Tko
Yes one of the studs must move.
Old Apr 17, 2012 | 02:03 PM
SirSpeedyZ's Avatar
SirSpeedyZ
I noticed a difference between stock and crawford headers on my DE motor, but my headers only cost $20 new
Old Apr 17, 2012 | 05:46 PM
tioga's Avatar
tioga
There is a photo out on the net I saw ones on how to put tomi de headers on a hr. Its one bolt you need to switch rather then putting it on the bottom you put it on top. Can't remember the site ****
Old Mar 18, 2020 | 06:22 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
soooo blast from 8 years ago seems all that's needed is a stud removal..? About to hit confirm and pay on OBX headers for my 370
Old Mar 18, 2020 | 08:39 AM
rustyschopshop's Avatar
rustyschopshop
you will have to change cats if you change to the different header.
Old Mar 18, 2020 | 11:11 AM
jhc's Avatar
jhc
General & Tech Moderator
True, (unless he's 1 of those daredevils running test pipes) plus a new tune.
