Please help with these map
Old Sep 7, 2009 | 04:33 PM
max-hid's Avatar
max-hid
Default Please help with these map
This is the map of my emanage ultimate and i want that some tuner see it and give your opinion of what my tuner did..im going to upload a video of the wide band with the car revng in 3th gear so you can see if there any problem..befor the 2k rpm in full thotle my cars mark 10 in afr in my wideband and then after 2,500rpm it becaise to do to 11.5.. have a vortech supercharger with 6.6 pound of boos..please check the timing also because i see something are very rare...thnaks for your help.. want to beging tuning my self my car and clear this map...[IMG][/IMG]
[IMG][/IMG]
Old Sep 7, 2009 | 08:09 PM
max-hid's Avatar
max-hid
this is the video of my aem wideband runing in 3rd gear
http://www.youtube.com/watch?v=hTeiuym0Hps
Old Sep 12, 2009 | 05:28 PM
streetzlegend's Avatar
streetzlegend
I wouldnt be able to tell you much about the ignition because i dont know how much timing the 350z ecu runs at WOT stock. but as for your a/f, it dosnt look too too bad, mid 11's is where you want it to be. You should be able to log your a/f with the EU, that way you know exactly at what RPM it dips into the 10's. You save the log, then open it after you stop the car, and click at the location where it dips into 10's, then go to your injector adj table and see what cell is highlighted, then remove a little bit of fuel.
Also, probably because your supercharged and u get same boost no matter the gear since its rpm dependent, but its always best to tune based on Boost, not Throttle Position. Since you already have it with throttle leave it.
Old Sep 14, 2009 | 05:47 PM
max-hid's Avatar
max-hid
ok...im getting tune againg because my tuner did a tune but he do it like my car was of tps not hot wire..that why in the bottom end to rich..im doing the new tuning this week and i will let you know what i do change..thanks for your reply and your help..
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
