Filled with Nitrogen!
Old Feb 8, 2008 | 10:32 AM
Zeebra's Avatar
Zeebra
Default Nitrogen problem now...
Side note...
Having my TPMS sesnor act up everyday after 10 minutes of driving on the same wheel (just one wheel) saying my PSI is low and then it goes away saying my tire psi is back to normal all the time.. Do I just need to replace it?
Thanks!!
Old Feb 8, 2008 | 10:38 AM
SpeedRcr's Avatar
SpeedRcr
nitrogen is no different than reg air...ive ran nitrogen since i got it for free from the dealer, it still leaks just like having reg air
Old Feb 8, 2008 | 10:51 AM
_NIZMO_'s Avatar
_NIZMO_
Originally Posted by jarulez9
Wow what a difference on the highway and even during hard cornering and stuff. Definately a must for everyone to get!
Thanks!!
your and idiot. nitrogen vs air makes no diff in handling
Old Feb 8, 2008 | 10:56 AM
Does the car float above the highway?
Old Feb 8, 2008 | 10:59 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
wonder if he has some nitrogen to sell?
Old Feb 8, 2008 | 11:16 AM
yusoslo's Avatar
yusoslo
it made him happy!!! but yeah the only benifit is at the track your tire pressure doesnt go up as much so you dont have to constantly bleed out your tires
Old Feb 8, 2008 | 12:37 PM
Zeebra's Avatar
Zeebra
Im sorry but at the same psi as air Ive definately felt a difference during AutoX... maybe thats just me... opinions are like NIZMO!
Ill just close this thread now.
Old Feb 8, 2008 | 12:39 PM
sofa king's Avatar
sofa king
ibtl
Old Feb 8, 2008 | 12:40 PM
redlude97's Avatar
redlude97
You realize that air is 78% nitrogen right? Gases behave the same at the same pressure regardless of composition
Old Feb 8, 2008 | 12:44 PM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Thumbs up I...
fill my tires with Kool-Aid. Makes cornering extra interesting.
Old Feb 8, 2008 | 12:48 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Mine are filled with helium. It makes the car feel like it's 0.5g lighter!
Old Feb 8, 2008 | 02:57 PM
yusoslo's Avatar
yusoslo
most are filled with bullsheit and hopes and dreams.
another thing I heard was it isnt supposed to eat at the tires as much...that what a mechanic told me but i never researched it.
Old Feb 8, 2008 | 03:10 PM
Get_Zwole's Avatar
Get_Zwole
i have nitrogen in mine my tires dont even touch the ground i just fly about 2 inches from the ground my tires last years.
Old Feb 8, 2008 | 03:36 PM
MR_X's Avatar
MR_X
http://www.sptimes.com/2005/09/28/Ta...our_tire.shtml
Old Feb 8, 2008 | 03:37 PM
MR_X's Avatar
MR_X
ah is nitrogen, not helium that we are talking about
Old Feb 9, 2008 | 07:15 PM
terrorist22's Avatar
terrorist22
You're using the wrong air.
By Charles Armstrong-Wilson, Sam Collins & Barbara Stanley Borras, RACECAR ENGINEERING MAGAZINE
ON THE GAS...
One of the most talked-about elements of the McLaren spy case was a special gas used by Ferrari in its tyres – in particular, an incriminating email from McLaren test driver Pedro De La Rosa to lead driver Fernando Alonso that revealed that the gas reduced the internal temperature and blistering.
In the email De La Rosa is quoted as saying ‘we’ll have to try it, it’s easy!’ Racing tyres are typically filled with air or, in more professional series like Formula 1, Nitrogen. But in an email from Alonso to De La Rosa he states it is ‘very important’ that McLaren test the gas that Ferrari uses in its tyres as ‘they have something different from the rest.’ He follows this up with ‘not only this year.
There is something else and this may be the key. Let’s hope we can test it during this test, and that we can make it a priority!’ It has been widely reported that the gas used by Ferrari was carbon dioxide and, whilst this is partially correct, it’s not the whole story.
Contrary to those that refused to believe alternate tire gasses could have a genuine impact on performance, Ferrari indeed developed an innovative solution. (For a revealing of all of the test results, purchase the December issue of Racecar Engineering.)
In fact, the gas used by Ferrari is a hydrofluorocarbon (HFC)-based mixture designed specifically for use in racecar tyres, though not dissimilar in composition to gasses used in refrigerators, which are comprised entirely of hydrogen, carbon and fluorine.
A team headed by Andrea Seghezzi of Monza, Italy, in association with Gruppo Sapio developed the gas and subjected it to extensive track testing.
It was discovered that the HFCs were able to effectively conduct the heat generated during the rotation of the tyre to the wheel rim at a more or less constant pressure. The wheel rim then acts as a radiator, exchanging the heat with the outside air, maintaining a lower internal temperature and preventing it from overheating. This is particularly effective on aluminium or magnesium wheels.
Racing rubber inflated with air also suffers from the effects of some internal chemical interactions, which damage the structure of the tyre, and can result in a sudden drop in performance. Due to the high capacity for heat transfer, tyres inflated with the new gas mixture achieve excellent longevity, since the temperature of the tyre is kept low and the pressure is constant.
After extensive tyre testing the best blend of HFCs was found to be 52 per cent Tetrafluoroethane, 44 per cent Pentafluoroethane and four per cent Trifluoroethane. This mixture, known as HFC R404 A, was found to be most effective in a racing tyre when it was inflated with a blend of 50 per cent HFC R404 A and 50 per cent CO2.
The use of refrigerant gas to cool the tires and radiate heat away from the carcass through the wheel is but one of many secrets McLaren was privy to.
The use of this new gas mix for tyres has implications far beyond Formula 1, of course, as using it allows teams to run softer compounds for longer, or to work the tyres harder.
It could also be that there will be worthwhile benefits in races run over longer distances, like NASCAR or Le Mans.
The court case continued without revealing the precise details of HFC R404 A, but it transpires that, despite the encouragement of the drivers, a Bridgestone engineer doubted whether the gas mixture would be effective if used on the McLaren MP4/22. However, it is thought that the McLaren drivers were not fully aware of the gas mix, rather they only knew of the CO2 element.
Old Feb 9, 2008 | 07:49 PM
Do you tie the car down at night so it doesnt float away?
Old Feb 9, 2008 | 07:53 PM
I knew that.
Old Feb 9, 2008 | 08:04 PM
Get_Zwole's Avatar
Get_Zwole
yeah its kinda like tieing your boat to an anchor i have 3 anchors in my garage i use on 3 points works well.
