What's my car worth?
For the mods: MOD's this is just a suggestion forum not a for sale one
Well I finally have to put my project z to the side if not sell it, I have been Mobilized with little notice and need to make some room in the garage, so I am see what i might get for my second Z with no motor. I appreciate your thoughts on what it will be worth. I know I would get more to part it out, but time is a constraint, so its all or nothing at this point as it will be a family member dealing with it if someone wanted to buy it. Heres a list of whats in it. Shell is an 03 350z MT touring super black Clean title w/ 60k mileage Forced Induction -Greddy TT with intercooler with larger wheels on turbos equivlant to a 20g with spool up of a 18g, welded on turbo out piping, Ceramic coated manifolds -Cooling mist FMGS water/alcohol injection -tial bov Engine components -2 Bare short blocks with cranks -1 set of heads with bc stg 3 cams, over size valves, ferrera springs and retainers and one hell of a port job (Injected's $5k ones) -1 set of heads with JWT stg 2 cams, stock valves (two are bent), JWT HD springs, mild port job -1 Set stock rev up heads -Pathfinder coolant kit -both revup and non rev up timing covers -Ported runners -LW Pulleys -Injected Performance solid Motor Mounts -L19 studs heads Fuel -ID 1000cc injectors -walbro 255 -AAM stage 1 Return -1 Extra set of fuel rails -Aeromotive Inline 340lph*new* Intake - Polished Plenum - Powerlab spacer Engine Management - Haltech -Uprev -Race Logic Traction Control *new* -Velocity tunning with External AIT sensor Cooling -pathfinder mod *new* -Koyo Raditor -Z1 Red silicone hoses -Oil cooler Gauges -Defi boost/egt -Innovate lc1 -Blue leds on all gauges stock and aftermarket Exhaust -AAM 3inch Down pipes *new* -AAM 3inch true dual *new* Drive train -2 x cd0009 trannies, 1 new with 5k and other with 30k (for parts ) -1 stock 03 tranny gear grind -OS Giken LSD with base axels -Z1 70A trans mount -18x9/18x10 tsw time attacks with nitto invos brand new on them -Stock rims -Nismo Short Shifter Suspension - Stance gr+ coilovers -Full adjustable arms front and rear -Akebono BBK F/R -Hotchkis Swaybars -Power grid End links -Cusco Strut Bar powdercoated red Interior -Sparco Harness Bar *new* -All blue guages including Nav -JVC Double Din Head Unit -Race Logic traction control, digital -Z1 HD Hatch Springs Exterior -Seibon GT Hood with sparco hood pins -stock hood/ bumper -Carbonfiber Nismo V2 spoiler -paint is 7.5/10 Misc -Hella supertones -Demon eye headlights with black housing 03's There is probaly more, but I am reciting from memory. All this car needs to be running is a clutch/flywheel, piston/rods, bearings to go with. I was so close yet so far....I AM NOT PARTING OUT, i want to know what i should expect as a single unit I know I can make more parting out, but I dont have a way of doing so. |
Nobody will buy a heavily modded car. If you do find somebody willing to buy, it could take you a year or more for that to happen.
As it has been said a thousand times before, sell the mods and return the car to stock. Otherwise, you might as well sell it for the price of a stock car as that will be the only way you can find a buyer. BTW - title fixed to match your post contents For the mods: MOD's this is just a suggestion forum not a for sale one Well I finally have to put my project z to the side if not sell it, I have been Mobilized with little notice and need to make some room in the garage, so I am see what i might get for my second Z with no motor. I appreciate your thoughts on what it will be worth. |
No one will buy all of that once. Different people have different needs, different goals, and most already have cars they want to mod. I'd say $15k maybe if the car isn't running.
People are trying to sell fully completed Z's with over $30k invested for low $20's. I'll buy some of that stuff though. Like the new AAM downpipes. |
What do you want for it?
Only problem with being a regular contributor is that members know the history of the car. Hope the sale works out better than this thread: https://my350z.com/forum/forced-indu...e-2-motor.html
Ouch. Maybe $15k tops.
You need to part. Get over it. |
Originally Posted by davidv
(Post 9367047)
just keep it unless you're absolutely in need of cash. It's true, you won't get anything near what you think you should get.
| All times are GMT -8. The time now is 01:13 PM. |
