350Z engine strong knocking sound after revving
Hi, I know I screwed up, but after revving very high after a cold start.
My engine started a strong knocking sound, it almost sounds like something fell off in a cylinder and is knocking the cylinder itself. Here is a youtube link: The noise goes up in frequency with rev, the idle rpm is still very stable, but the throttle response seems very very slow, and the car is clearly slower than normal. Also, I had a grinding 3rd gear, but I do know if transmission is the problem here. Please give me some thoughts, Thank you very much! |
Thrown rod....
What else is new? Young immature 350z owner trashes another car... |
That is a very bad sound. Your camshaft is ruined, and your valves are "toast."
You are looking at an engine rebuild or buying a rebuilt engine. |
Motor is trashed
do a compression test.
report to us the compression readings. drain the oil and remove the oil pan check for metal shavings. then go from that information. its hard to diagnose a car just by sound can be plenty of symptoms dont jump the gun until you get concrete facts. |
@Tcode I just cried laughing haha... ugh that was great.
@misaka "after revving very high after a cold start." this is like saying "after having sex with that prostitute I got aids." cold starting a car and reving it up is begging to throw something. |
100% rod knock from spun bearing.
So you high revved your car cold, how bout somebody shakes you from a deep sleep then you run a marathon. Doesnt sound like that would be fair way to treat you does it?
https://cimg9.ibsrv.net/gimg/my350z....b2617139a6.jpg
Its not cold unless your car tells you it's cold... Thats going to be an expensive mistake though... Can only do that with rental cars or something still under warranty. |
the sound hes experiencing was something "kind of similiar" except mines was deeper sounding from the exhaust during the break in period of my engine. it turned out to be piston slap though not really a big deal only happened during cold startup and once the car got warm my sound went away.
Why in the hell would you rev the piss out of your car on a cold start?
Buuut... Start looking for a new engine. These meme's are killing me. |
Same Problem
Hi, I wanted to ask you if you've solved, I have the same problem |
Originally Posted by Valdet HC
(Post 10982700)
@Valdet - The post is like 3 years old now so it’s unlikely you’ll get a reply but like Beal said just give us 30 secs of audio/video and we will take a look.
Video My engine
Originally Posted by bealljk
(Post 10982713)
Valdet - load up a video with sound of your engine. Bent rod / spun bearing ...
