PCV hose delete??
Does anyone know if you can remove the pvc hoses connected from the valve cover to the intakes? Normally I wouldn't want to do this, but I broke one of the plastic pieces and cant find a replacement anywhere. I'm tempted to just stick a breather filter on the valve cover and caps on the intakes. Anyone know if this would work?
I just asked this same question in the vq35hr forum as I am looking to make a custom intake and I will save about $150 if I'm able to just put breather filters on the pcv valves. I actually got this idea because I saw some turbo kits on the 370z running that. The general consensus was that I would have no issues doing that. Just make sure you block off the opening on the intake side, and connect a breather filter on the pcv side.
thanks for the help
Yes just drill out pvc and put breather filter and cap plenum. I just did that a couple weeks ago.
just did mine yesterday got rid of my oil consumption issue and made the engine look way cleaner
Does this really do anything for oil consumption? I am trying to fix my g35 been burning oil for over 100k
Originally Posted by johndoesdamage
(Post 10456154)
Originally Posted by AARONHL
(Post 10531630)
Also, no this would not stop the oil consumption issue. |
I wouldn't go ahead and say no it won't stop the issue. On the de if u put a catch can in it stops oil consumption because all it was doing was looking in the plenum. If it's the same case for the 37hr then I would assume it would help.
