Turn signal not cancelling Anyone?
Have a 06 g35 few years ago I took airbag out to remove parts I was going to paint. Put back together and ever since when I put turn signal on and make the turn it will not cancel out. Anyone have any suggestions? Also have a airbag light on. Idk if this is something from that as well. Any help would be great. Did a search and not much on our cars about this. Thanks!!
There should be a "turn signal canceler" piece inside the steering wheel. It's usually plastic, and has a couple of tabs on it that are supposed to turn the signals off. It needs to be aligned properly when you remove/replace the steering wheel, so my bet is it's not aligned properly.
Originally Posted by Freise
(Post 10848806)
Easy fix. Wasn't aligned correctly took everything off aligned it correctly and wham works. Thanks buddy appreciate it!!!!
