ipod connection.
so im completely stupid when it comes to electronics...i have an 05 non bose head unit...i want to be able to play my ipod music, but have no idea as to how to accomplish this...so what do i need to buy?
hmm get the flame suit on! lol ill be nice before the fire gets hot. You will have to get a aftermarket deck with a ipod connection. Also ( i wouldnt recommend it) there is a thing were you can tap into the stock head unit wires to hook up a ipod connection, not sure how it fully works because i never looked into it sense i have a aftermarket head unit. Honestly i recommend the head unit. Get it done right, get it done right the first time.
There are FM modulators you can use ...cheapest way with the stock setup
FM Mod
BTW, FM frequency response is 30 Hz to 15 kHz (not to mention the signal to noise), so it's kind of lo-fi...
Originally Posted by zerostyle
(Post 8231887)
yeah for now all i want is to be able to random play my songs through the headunit...as far as controls that will come later when i replace my headunit. but right now im working outside inside...once i finish some exterior mods then i will begin on the inside.
(Post 8231887)
I've had a USASpec PA11-NIS in my 2005 Track model for almost 5 years. With the latest cable, it works great with my iPhone 3G (it worked fine with my older iPods with the older cable). It also has an Aux in (RCA jacks), so I've got my XM satellite radio plugged in as well. |
+1 ^
I just installed the PA15-NIS from USA SPEC as suggested above (Newer version). Works great. Can control the iPod thru the head unit and comes with AUX-IN. Easy to intall once you pull the dash. Got mine from here but might get it a bit cheaper elsewhere http://www.crutchfield.com/p_581PA15...s&ssi=0&tp=120 |
they have it for cheaper on ebay. 120 shipped
thanks a bunch guys :thumbup:
USASpec PA11-NIS
I just purchased the USASpec PA11-NIS online. I have a 2006 350Z (Automatic) and cannot figure out how to remove the center console. All the instructions/pictures I locate online show how to remove from a stick. Can anyone provide me with detailed instructions? Thanks!
Originally Posted by court777
(Post 8236298)
Remove the silver/gray ring around it. Find a flat screw driver. It pulls up but you need to pry it carefully so you do not scratch. Move the knob into the neutral position. Key should be in to do that but you do not have to completely start the car (Place some blocks in front and back of tires for safety and engage the parking brake). This alows you enough room to pull out the lower part containing the A/C controls, slide it up and out to disconnect from the cables as outlined in all the dash removal instructions you find. You need to leave it in the neutral position otherwise there is no way you can slide the dash foward, trust me, I just went thru this (I installed the PA15-NIS). Hope this helps a bit. I wish I had taken some pics |
does the pa15-nis work for 06 base model meaning non bose and no 6 cd changer. i may have done the wiring wrong but my ipod freezes on a screen.an suggestions?
Originally Posted by BeaReel
(Post 8250031)
http://usaspec.com/product.php?ProductID=30 |
(Post 8231887)
Just put this puppy in my Z this past Saturday. Works great. It has a USB cord with iPhone port connection. I had mine wired through the center console box. Just open the box, connect my iPod, shut the box, control everything from the head unit.
http://www.e-xantina.com/images/b_cda117ri.jpg |
is that this one?
https://my350z.com/forum/members/aus...creen-out.html |
