antenna amp testing
I think my antenna amp is bad. can it be tested ? If I unplug it should I see 12v off of the plug to the amp in the trunk ? 2004 z
What’s a antenna amp? |
It is the amplifier that runs your radio antenna in the trunk of the car.
I think I also may have a bad antenna amp. anyone know wheres its located on a 04 roadster and how do you test it. Thanks
It is in the trunk on the left side behind the padding. Mine was not getting power. changed the wireing on the new radio and fixed it. If you need a new amp i bought a used one ans don't need it now.
Ok, my system is all stock. I was wondering if the antenna amp went bad. Would you know how to test it?. And how much u want for the amp.
Not sure how to test it. I did check mine by seeing if i was getting power back to it. I just strip a little spot on the small wire to the amp in the trunk and used a 12v tester to make sure I had power and I did not . If you are getting power and still not working maybe the amp. I would sell the one I have for $10.00 plus postage if you need it. you need to pull the small plugs holding the carpet to get to the amp. lift the center on the plugs and the plugs will come right out then. I had to pull the plastic piece across the bottom back of the trunk also to get the carpet pulled back .
Hey Wildl - I'm guessing your heart's in the right place here, but before you post a For Sale thread, READ THIS.
You have not been on long enough to post a For Sale thread, you haven't met any of the sale guidelines and these rules are in place for everyone's protection, including yours. Send a PM to a mod (see the link above) if you have any questions. |
