MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Autocross/Road (https://my350z.com/forum/autocross-road-305/)
-   -   RPF1's 17x10 +38 all around (https://my350z.com/forum/autocross-road/483751-rpf1s-17x10-38-all-around.html)
bnag0 Apr 20, 2010 07:33 PM
Anyone run this spec for the track?
I ran it into the offset calculator and it sticks out 14-17mm past the stock wheels, I see that a lot of people run with the 18mm offset and have to adjust camber and maybe roll the fenders to make it work. I rather go for a near stock set up with a wider wheel so i don't have to worry about it.
What is your opinion?
MyV6IsFast3r Apr 20, 2010 07:43 PM
What size tire are you going to go with?
raz0rbladez909 Apr 20, 2010 07:48 PM
+38 is a pretty weak offset for the z, i'm running the fn's in 17x10 +12 all around with 275 40's, im sure you can at least do the +25's without worrying too much about rubbing:thumbup:
bnag0 Apr 20, 2010 07:54 PM
Not entirely sure yet
03threefiftyz Apr 20, 2010 07:59 PM
Must be at a relatively close to stock ride height........no?
bnag0 Apr 20, 2010 08:01 PM
so with your +12 offset on a 10" wide you didn't have to adjust your camber or roll your fenders?
The RPF1 17x10 only come in a +18 or +38 offset. And i have heard from many that the +18 = rubbing
raz0rbladez909 Apr 20, 2010 08:12 PM
Well if you lower at all of course you're going to have to adjust camber, and yes I am on rolled fenders, no pull or anything just a roll. Before i was running the 18 in rpf1 9.5 +15 and 10.5+15 so i don't think you'd have a problem running +18 all around if anything you might have less likelyhood of having to roll. I'll have to find some pix, gotta upload em first
raz0rbladez909 Apr 20, 2010 08:13 PM
And nope not at all close to stock ride height, not super slammed or anything but definitely alot lower than stock.
03threefiftyz Apr 20, 2010 08:16 PM
Pic por favor :).
bnag0 Apr 20, 2010 08:18 PM
I do plan on lowering the car... Not slammed but just enough to see a little space on top of the tire... I plan to go with buddy club racing spec coils and i guess i could deal with a camber adjustment. Hopefully i wont have to roll fenders as well...
raz0rbladez909 Apr 20, 2010 08:28 PM
Originally Posted by 03threefiftyz (Post 8320427)
Pic por favor :).
As requested
<a href="http://s947.photobucket.com/albums/ad318/raz0rbladez909/?action=view&current=mycar1.jpg" target="_blank"><img src="http://i947.photobucket.com/albums/ad318/raz0rbladez909/mycar1.jpg" border="0" alt="Photobucket"></a>
<a href="http://s947.photobucket.com/albums/ad318/raz0rbladez909/?action=view&current=mycar2.jpg" target="_blank"><img src="http://i947.photobucket.com/albums/ad318/raz0rbladez909/mycar2.jpg" border="0" alt="Photobucket"></a>
03threefiftyz Apr 20, 2010 08:35 PM
Is that car used on the track? Looks like under load there would be no way to turn the front wheel without significant rubbage.....
I ask because this is the autox/road racing section......and I figure the OP is wanting this combo for the track.
raz0rbladez909 Apr 20, 2010 08:42 PM
Ah not as of yet, I've been wanting to go to willow springs and try the setup out, just haven't had the time yet. Just realized what section it was in saw it from the main page, but if its any difference every now and then I'll drive the canyons and haven't had any problems yet, but I have also rolled the fronts a little bit so that could be the reason i'm not getting any rubbing. I don't doubt that something may eventually rub when I'm on the track, but just figured i'd throw some info out because i would think that +38 would be a bit overconservative?
bnag0 Apr 20, 2010 08:43 PM
Correct.
I just want to know if the 17X10 +38 would really look or perform all that bad, it is still 17mm extended past the stock wheels...
And if the +38 is no good then how much camber will i need for the +18 if i am going to drop the car slightly
03threefiftyz Apr 20, 2010 08:45 PM
A lot of the more serious guys run higher offests to run uber wide hoosiers, etc.
This is mine....18x9 rpf1's 265/275 Star Specs +15 front +20 rear....~1" lower than stock:
http://farm3.static.flickr.com/2147/...0575422e_o.jpg
bnag0 Apr 20, 2010 09:08 PM
I was trying to find a 17" wheel what is your opinion on 18 vs 17 with this wheel?
03threefiftyz Apr 20, 2010 09:19 PM
I'd go 17's......tires are much cheaper....just my .02.
Stillen Z Apr 20, 2010 09:28 PM
What tire sizes did you run on your 18" RPF1s and did you have any rubbing issues?
INTIMAZY Apr 20, 2010 09:45 PM
You need to decide what size tires you want to run first. a 265/275 is not difficult to fit up front. An RPF1 in +38 with a 10mm spacer will do it EASILY with room to spare.
My concern is that a 10" wide rpf1 with +38 offset up front will not clear the knuckle/spindle without a spacer. I have a pic up in the "aggressive wheels & fat tires" thread of my front setup (I'll get more up soon). It's a 18x10 +35 and it rubs on the inside with a 305 Kumho V710. I have a 5mm spacer on and it clears just barely. I'm playing with mere millimeters to make this fit. If you want a seriously large tire up front you will need to mess around with spacer sizes to make them fit. Here are a few threads that will help with your RPF1 questions as well as other big tire setups.
https://my350z.com/forum/wheels-and-...r-rolling.html
https://my350z.com/forum/wheels-and-...4-corners.html
Good luck
raz0rbladez909 Apr 21, 2010 03:37 AM
I ran 245/45's up front and 275/40s out back, only used the 245/45's for a short while because i had them lying around, but the sidewall is way too tall for anything serious beyond random street stuff, i've heard good things about245/ 40s though but sadly i got rid of my rpf1's for the square setup i have now
