G35/TrackZ Brembo's VS STi Brembo's
What's the difference? I believe the STi Brembo's are bigger.. ?
From looking at a friend's STi I thought they looked to be the same.
I thought they had the same aftermarket parts numbers for pads and rotors. They should be exactly the same.
how about with evo brembo. are they the same
Well, Z's are four-piston front/two piston rear with I believe 12.1" calipers up front and 11.x" in the rear. What are the specs on the Evo/Sti?
BremboŽ performance brake system. 4-wheel disc, ventilated front and rear. 4-channel, 4-sensor Super Sport ABS with Electronic Brake-force Distribution (EBD) Front: 12.7 in./Rear: 12.3 in. Yar they are slightly bigger. I believe they are both 4piston also. |
Different piston sizes, different front pad shapes, different rotors, different mounting points.
Things that are the same(maybe): paint, logo, rear pad shapes Sti vs Evo Brembos: Different piston size, paint, rotor size |
The STi's are much bigger.
Actually the Z brembos are slightly bigger.
From subaru's website the STI Brembos are: Front - 12.7 x 1.2 Rear - 12.3 x 0.8 The Z Brembo are: Front - 12.8 x 1.2 Rear - 12.7 x 0.87 Both have 4 piston front, 2 piston rear. |
From subaru's website the STI Brembos are: Front - 12.7 x 1.2 Rear - 12.3 x 0.8 The Z Brembo are: Front - 12.8 x 1.2 Rear - 12.7 x 0.87 Both have 4 piston front, 2 piston rear. The STi front brake pads are about 20% bigger than the Z's. The front caliper is also much beefier on the STi. |
| All times are GMT -8. The time now is 10:46 PM. |
