Koni vs. Nismo s tune
Im looking to do suspention, how is koni shocks with either hotchkis, or eibach pro kit springs, compaired to nismo s-tune does anyone know stiffness and handling wize whats better, or have any other cheap solution.. Its a street car that i drive very fast and do a good amount of track days with...
I would highly recommend the Konis with a linear spring setup.
which springs would they be, ok so i have Rota P45r (265/35/18---285/35/18)
And a front lip(worried about scraping) what springs would you recomend. |
We do have couple of board members with TomMotor sport coilover springs and Tokico D-specs, that would get you decent linear spring rates and adjustable shocks (compression AND rebound). http://www.thezstore.com/store/merch...ry_Code=PSDC14 http://cgi.ebay.com/ebaymotors/03-04...spagenameZWDVW Ad has expired but you get the idea. Here is how your choices stack up against one another. Unless you make a diffferent product choice, your other choices won't measure up to the S-tune setup, Koni valving will be better but spring rates aren't as aggressive. Eibach 350Z progressive springs 1”/1” drop Spring rates in LBS initial/final front 296/384 initial/final rear 316/421 Hotchkis 350Z Linear springs .6”/.8” Spring rates in lbs 340/330 Nismo S-tune (twin tube construction, uses progressive springs) 350Z .8"/.8" drop Spring rates 448/504 |
Originally Posted by Gsedan35
Koni's with mild drop amounts or enough spring rate to keep you off the bump stops if your going lower then .8" such as at least 560lbs (I had them with 448lbs).
We do have couple of board members with TomMotor sport coilover springs and Tokico D-specs, that would get you decent linear spring rates and adjustable shocks (compression AND rebound). http://www.thezstore.com/store/merch...ry_Code=PSDC14 http://cgi.ebay.com/ebaymotors/03-04...spagenameZWDVW Ad has expired but you get the idea. |
Originally Posted by Fluid1
What springs did you have that were 448lbs? Thanks,
http://pics.montypics.com/gcoupe35/2...r1_040_18a.jpg http://pics.montypics.com/gcoupe35/2...r1_058_27a.jpg |
