Hardlines-vs-Braided lines
I was hoping someone could help me on here that has better knowledge about brake lines and what's better. I'm doing the Brembo upgrade on my Z and the kit I purchased didn't come with the hard lines. I've done some research and spent a few hours on the phone w/ AP, Goodrich, Stoptech, and a few other brands/companies trying to figure out a solution. A few of the guys I spoke to told me that the OE hard lines are better than any braided line since they will not expand at all. Some guys told me that the braided were better because they would give better feel and response. I ordered the braided lines for the Brembo equipped Z and have those which are the ones that meet between the two hard lines. I'm up in the air now because I'm not sure if whether to order the hard lines from the dealer or send the ones I currently have back and go with the braided lines from the bleeder line to the caliper. I can get the braided lines for about $60 plus shipping (any of them) and the hard lines for about $20 at the dealer (really good hook up). What do you guys think is the best option? This is going to be a temporary kit until I save up enough for some Endless or Rotora's. Any suggestions would help since I've had the brakes for about a month now and it's killing me to just have them sit there.
I searched on the forum but kept getting the DIY threads. Thanks in advance! |
you need braided "flexible" lines from the body to the calipers. hardlines from the the abs motor to where the connect to the braided lines. Is that what you were looking for?
I haven't heard of the entire system being hard lines. |
I would think you want some 'flex' when hyd lines are attached to moving parts. Hard lines are good when they are attached to things that have little to no movement.
Put hard lines everywhere. No flex will give awesome pedal feel. Please youtube the first test drive thanks.
Originally Posted by twistiert
(Post 9086886)
Originally Posted by drivessidewayz
(Post 9086931)
Originally Posted by BornSlippyZ
(Post 9086948)
Originally Posted by 0jiggy0
(Post 9086985)
Just do flex from the caliper to the hard line is wheel well. Simple, easy and you will never be able to tell the difference. No one to include Emerson Fidipaldi will be able to tell the different with the extra 2 inches of hard line replaced with braided flex line.
Why would you want crappy ass Rotora or over priced GayDM Endless stuff later? |
You have to plan for suspension compression and rebound in front and back. Also the steering in the front. I don't see how it would be possible to make a hardline do that. Maybe some swivel joints?? Whats the reasoning behind wanting this when most people are satisfied with braided SS lines?
Originally Posted by jmahad01
(Post 9087092)
Originally Posted by YoungBB
(Post 9086826)
nvm
(Post 9087149)
WTF is that supposed to mean. He does not say if he wants to go all the way to the caliper or not.
Whats the reasoning behind the oem hardline on the brembo's? just to position the line better?
(Post 9087169)
He is asking if he should run the braided lines that connect to the hard line in the wheel well directly to the caliper or run the braided lines that connect the hard line in the wheel well to the OEM hardline that is connected to the caliper. If he does the version to the OEM hardline on the caliper, he needs to order the OEM hardline from the dealership because his Brembo's did not come with it when he bought them used.
(Post 9087171)
https://my350z.com/forum/brakes-and-...bo-brakes.html Found some pucs |
Terra... You're completely correct and seem to be the only who understands and knows how the original system looks and works. I figured the same when it came to the 3-4 inches of hard line to braided. I just wasn't clear as to why they would suggest that the braided line would be better than a hard line (of course besides sales). Either way I just picked up the hard lines and am installing them tomorrow. Eventually when I upgrade I'll have to go with full braided. Thanks for the help and clearing that up.
What do you suggest besides Rotora's and Endless? I was personally thinking of just going with the Concept Z brake upgrade since when put up next to some of the other kits it's actually a bigger caliper system. |
(Post 9089458)
I had Stoptech's before; wanted to try something different this time around. Not a big fan of Wilwood though. Th ekit would just be for looks for the time being either way
(Post 9087027)
Come on guys; let's hear it for the smart ass that wears a helmet!!! |
Originally Posted by R350Zz33
(Post 9090462)
he don't need a helmet he's from ny
so why you in florida theres old people there
