Rotora BBK From 2003-2005 on 2006+?
hi guys - I have a 07 non brembo 350z an have been looking to get a BBK for the longest time now..I recently stumbled upon a rotora big brake kit - 355mm 6piston front and 355mm 4 piston rear. The only catch is that this kit came off of a DE 350z and idk if it would work just as good on a HR Z. I have placed several phone calls to businesses asking if the DE kit would work on a HR Z and the answers I've gotten was that the kits are very similar to one another however the model numbers are slightly different (rotora 6piston 355mm DE version: rfk01506 vs HR kit: rfk01509) I've heared people using the DE kit on their HR however I want to know if anyone has hands on experience with this and could chime in PLEASE!! it's a large purchase and I need help from fellow Z buds. Thx guys..
It's a large purchase and I know you want the right thing for your car, look at something other than Rotora.
Originally Posted by germanguy818
(Post 9761963)
(Post 9762195)
Replacement parts and pad selection suck, but the do look pretty for a non used application.
Appreciate the feedback - has anyone made experience with this?
Stoptech also makes bbk specifically for 03-05 and for 06-09 350Z's. They highly recommended not to run their bbk that are made for 03-05 on 06+ due to brake bias like ronn1 mentioned above.
Also, buy what ever brand you like and ignore that terra dude. |
Originally Posted by Kuhan
(Post 9762789)
Originally Posted by ronn1
(Post 9762277)
I wouldn't make an investment like this with the wrong application. There's a REASON why kits are different. Your car has pretty damn good brakes as is, and it's entirely possible that, in this case, the wrong application could result in INFERIOR braking to OEM. You won't get the proper brake bias, since DE brakes are MUCH different than 06 up cars.
(Post 9762195)
(Post 9762789)
Also, buy what ever brand you like and ignore that terra dude. Brands are pretty much irrelevant to me - I take the car to mostly car shows and occasionally the drag strip/circuit racing. Any brand should suffice in my case! Thx or the help |
(Post 9763217)
why is that, do you sell the mentioned product or something? OP , stick to the brands that you can easily get parts for and will not fold tomorrow.
(Post 9763246)
Thank you for the feedback! I've also called a few places and the main difference ive been told was that piston volume is different for de and hr applications so it could lead to dangerous braking due to the specs being thrown off. Man I really want the kit tho...been looking for a while now! Thx again dude
(Post 9763283)
I've been thinking about this...since you're changing front and rear with same kit, piston volume shouldn't matter...since they're MATCHED. The only thing I can think of is that the master cylinders may be different on later models....but you see people updating pre 06 brakes to 06+ and there aren't any problems there! Based on this reasoning..you should be fine.
(Post 9763257)
rotora has been around for a while an parts are floating around everywhere if you know where to look.
(Post 9763299)
That's what my question to shops were but I was still given answers not in my favor. I've contacted rotor tech department asking this question and I am still waiting to hear back from them.
(Post 9763283)
I also agree a matched set should be fine, other brake companies only offer one BBK for the car fron 03 to 08 and they work fine.m |
(Post 9762299)
they will fit |
