11's possibly on my tires?
Just went to the strip for the first time this weekend and ran a 12.384@116.49. I know my car can run 11's if I ran DR's, but not sure if the tires I have on now can do it. I ran a 2.123 60ft time on my BFG KDW-2's.
http://www.mp-racing.net/1238slip.JPG |
that's hard to say. with that much power you're probably spinning well into 2nd am i right? i'm sure if you ride the clutch through 1st and 2nd you could possibly cut that 60 ft. down a bit and prevent spinning in 2nd. i would just pick up some DR's, it'd be easier on your clutch. Nitto555R's are extremely nice.
- Thanks for posting a time slip. Much appreciated. Excellent ET. I can see a possible 12.2 seconds on street tires. And you’re looking for 11.99 seconds on drag radials? I think that’s pushing it but who knows.
I think your pretty much maxed out with that time on Street Tires. The best i ran was a 12.4 on Street tires. If everything goes right, and from your time slip I think a 11.70 is probably the best with your current setup and DR's.
Thanks I kinda figured the answer, but figured I would ask. I bet I could squeeze out a slightly fast 60ft time though. Maybe high 2.0's.
11's on your tires now? I would say no. Aim for a low 2.0 60ft, and around a 12.1....
I am going with no
get some bfgs or mickey thompson street radials |
Another NO.
With my street radials, my best time is... 60' 1.948 1/8 7.936@92.4 1/4 12.1@117.7 You might be able to get ~12.1 or so with 1.9xx short time. On a side note: with your power, I would think you'd have bit higher trap speed. Just wondering. |
Turn up the boost to 9 PSI for 3-4 gear :D
Since we are on the subject. Where is a good site to check out tires. I tried tirerack.com but it was a little confusing for me.
delete this one
| All times are GMT -8. The time now is 11:42 PM. |
