Drag NHRA, IDRC, IHRA, NDRA
11's possibly on my tires?
Old Nov 15, 2005 | 04:09 AM
002-M-P's Avatar
002-M-P
Default 11's possibly on my tires?
Just went to the strip for the first time this weekend and ran a 12.384@116.49. I know my car can run 11's if I ran DR's, but not sure if the tires I have on now can do it. I ran a 2.123 60ft time on my BFG KDW-2's.
Old Nov 15, 2005 | 06:20 AM
JRaptor2000's Avatar
JRaptor2000
that's hard to say. with that much power you're probably spinning well into 2nd am i right? i'm sure if you ride the clutch through 1st and 2nd you could possibly cut that 60 ft. down a bit and prevent spinning in 2nd. i would just pick up some DR's, it'd be easier on your clutch. Nitto555R's are extremely nice.
Old Nov 15, 2005 | 07:28 AM
- Thanks for posting a time slip. Much appreciated. Excellent ET. I can see a possible 12.2 seconds on street tires. And you’re looking for 11.99 seconds on drag radials? I think that’s pushing it but who knows.
Old Nov 15, 2005 | 08:15 AM
barthelb's Avatar
barthelb
Master
I think your pretty much maxed out with that time on Street Tires. The best i ran was a 12.4 on Street tires. If everything goes right, and from your time slip I think a 11.70 is probably the best with your current setup and DR's.
Old Nov 15, 2005 | 08:56 AM
002-M-P's Avatar
002-M-P
Thanks I kinda figured the answer, but figured I would ask. I bet I could squeeze out a slightly fast 60ft time though. Maybe high 2.0's.
Old Nov 15, 2005 | 10:44 AM
Alberto's Avatar
Alberto
Cranky FI Owner
11's on your tires now? I would say no. Aim for a low 2.0 60ft, and around a 12.1....
Old Nov 15, 2005 | 10:51 AM
95snoozer's Avatar
95snoozer
I am going with no
get some bfgs or mickey thompson street radials
Old Nov 16, 2005 | 12:36 PM
1SLOWZ's Avatar
1SLOWZ
Another NO.
With my street radials, my best time is...
60' 1.948
1/8 7.936@92.4
1/4 12.1@117.7
You might be able to get ~12.1 or so with 1.9xx short time.
On a side note: with your power, I would think you'd have bit higher trap speed. Just wondering.
Old Nov 16, 2005 | 12:44 PM
Zexy's Avatar
Zexy
Turn up the boost to 9 PSI for 3-4 gear
Old Nov 16, 2005 | 12:52 PM
Bick350Z's Avatar
Bick350Z
Since we are on the subject. Where is a good site to check out tires. I tried tirerack.com but it was a little confusing for me.
Old Nov 16, 2005 | 01:37 PM
Bick350Z's Avatar
Bick350Z
delete this one
Old Nov 16, 2005 | 01:57 PM
002-M-P's Avatar
002-M-P
That always works, but not happening at this point. Maybe when I get some tires that can hand that power and some more money incase I damage the motor
_bit
Oct 2, 2015 07:49 AM
