Setup with PBM SAK kit
What alignment spec setup is everyone running with the pbm kit,
Just installed this kit over the weekend I know I have way more adjustability With this kit it's crazy. Also I'm pretty weary of having it aligned at a regular shop. |
First find someone who knows there stuff when it comes to alignments. I took it to two different guys who said they could do it 8 hours later they couldn't do it. I finally found a guy gave him my specs and 4 hours later its perfect.
front -3 camber toe 1/8 out caster +8 rear 0 camber toe 0 |
rear 0 toe
0 camber front 9 caster 4.5 camber 1/8 toe out |
Rear:
-2 camber 1/8 toe in Front: 8.5 caster -6 camber 1/8 toe out |
Rear
1/8 - 1/2" toe-in depending on how the car slides sideways vs traction. Use tire pressure for sidebite adjustment and add toe for more fwd bite. 0 camber or plus 0.5 if you have lot of grip/body roll/squat. Front with PBM Pull back caster closer to 7 or high 6 by shortening the diagonal arm "banana shaped arm", this will stop overcentering once you shaved the spindles to get max angle out of the kit. Front toe: 1/16" total out for fast drifting. 1/4" total out for slow drifting (front of car will turn a tighter radius). Front camber: -4.5 ish. |
We need a thread that is sticky'd for this. lol. Cause Ill need it in a month or so.
front
camber -7 caster +9 toe out .1 rear caster stock camber -.1 toe 0 https://cimg2.ibsrv.net/gimg/my350z....2f57eca4e2.jpg https://cimg3.ibsrv.net/gimg/my350z....1397181e33.jpg https://cimg5.ibsrv.net/gimg/my350z....4a0b075a1c.jpg |
Originally Posted by nichols
(Post 10559432)
front
camber -7 caster +9 toe out .1 rear caster stock camber -.1 toe 0 https://cimg2.ibsrv.net/gimg/my350z....2f57eca4e2.jpg https://cimg3.ibsrv.net/gimg/my350z....1397181e33.jpg https://cimg5.ibsrv.net/gimg/my350z....4a0b075a1c.jpg Love coming into the forum and seeing this!! |
thanks a lot @boltup89 check out saving a lost cause. this thing has had a complete makeover
Originally Posted by boltup89
(Post 10389868)
Just installed this kit over the weekend I know I have way more adjustability With this kit it's crazy. Also I'm pretty weary of having it aligned at a regular shop. Left Front: Camber: -3.8 Caster: 6.4 Toe: -.01 Right Front: Camber: -3.7 Caster: 6.1 Toe: -.01 Left Rear: Camber: -1.8 Toe: .07 Right Rear: Camber: -1.8 Toe: .06 |
Since the kit allows the knuckle to pivot about a single point instead of 2, our scrub radius increases considerably! My front wheels are 9.5" wide and have an offset of 0 (my scrub radius is out of control now). The first time I got sideways with the kit, the car felt very twitchy and sensitive. Didn't slide near as smooth as it used to :(
I want to ask what front wheel widths and offsets some of you guys run. |
