Idle adjustment
Does anyone know how to adjust the idle without changing the ecu? I just want to raise the idle from 700 to 1000 so that it idles smoother.
Thanks. |
If you can go back to nissan dealer and ask them to bump the idle up for ya if you have a '03 or '04 (I think) model...
cheers, richie |
Ive asked all the local dealers, and they want anywhere from $95 to $110. Seems kinda high...Oh and another dealer said it CANT be adjusted haha. Anyone know how much their dealer charges?
My dealer said it was "normal" and wouldn't bump it up for free. :(
One of the dealers said it would take 45-50 minutes haha
I had my dealer do it they first HAD to do an OBD scan $80.0 than raise the idle with consult for another $80.0..
What would increasing the timing do? And what did you increase it to?
S/C's tend to sound loud at idle and upping the rpm reduces the sound.
besides I don't see any worthwhile gains in bumping timing. |
"besides I don't see any worthwhile gains in bumping timing."
I think he meant increasing rpm!! |
timing and idle are two different things. I'm just responding to his question about bumping "timing"
Yeah, but thread is about raising rpm!
I've done it myself with a consult. The whole process takes about 7 minutes start to finish. The ONLY thing that could make this take longer is if the car wasn't at operating temp as the Consult doesn't allow you to make changes until the car is at 195 F. But thats IT. And it just takes a quick lap around the block to change that. As for advancing timing you can only bump it up 3 degrees more advanced or retarded then stock via the Consult. When N/A advancing it 3 degrees helps the car pull a little better through the midrange. This was a popular mod in the QR25 crowd.
Originally Posted by chimmike
you don't want to increase ignition timing on these engines as they're already close to the ragged edge of knock on 93 octane gas.................if you bump up ignition timing the knock sensor will go crazy and bump back timing, killing power.
besides I don't see any worthwhile gains in bumping timing. I had mine advanced 4 degress and after a while it looked like it was solid at 3 degrees advanced, when he had the consult it alllowed him +-5 degrees. |
Originally Posted by westpak
I had mine increased and had no problems, as mentioned it does help.
holy crap... those US dealers are crazy.... we got those type of services (raise the rpm) for FREE... and whenever you drive the car into the dealer, the car should be at its optimal operating temp. anyway... so it should be just a 5 to 10 mins job... Probably down in Australia, we have already paid for those services when we buy our cars at much higher prices than you guys over there.. :)
cheers, richie |
Yeah well you get robbed here in America :D
MIAPLAYA, can this also be done on 04 Z's? |
