MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Engine & Drivetrain (https://my350z.com/forum/engine-and-drivetrain-50/)
-   -   This doesn't look like VLSD does it? (https://my350z.com/forum/engine-and-drivetrain/437694-this-doesnt-look-like-vlsd-does-it.html)
2fasst May 30, 2009 07:41 PM
2 Attachment(s)
My car is a 2008 Touring so it should have VLSD. However I went to install my Nismo diff cover today and the gears look like open gears. I thought VLSD should be a sealed unit.
How can you tell? Here are two pics of my pumpkin opened up.
John H. May 31, 2009 10:22 AM
The info you need can be found here....
https://my350z.com/forum/engine-and-...-question.html
INTIMAZY May 31, 2009 07:25 PM
I'll take pics tomorrow of an open diff if you like, but that unit in your picture looks like LSD to me.
bbs350z Jun 1, 2009 02:21 PM
thats a vlsd for sure. also every z comes with vlsd except the base. im 100% on that, i just did mine.
2fasst Jun 3, 2009 10:25 PM
thanks guys. vlsd doesn't last that long anyway. so maybe i'll upgrade in anyways. Would love a Quaife but mine isn't base so probably doesn't fit.
bbs350z Jun 3, 2009 11:33 PM
why wouldnt it last long? mines lasted just fine, high hp guys dont have problems either
INTIMAZY Jun 4, 2009 08:08 AM
They last a long time as long as you change your fluid... There are Quaife models that fit automatics, base, and VLSD models so that should not be a problem.
If you do any organized racing an aftermarket LSD is a great buy... otherwise the VLSD does its job OK.
kramykram Jun 5, 2009 12:59 AM
it does not matter if you change your fluid or not with the stock. the vlsd is a sealed unit with fluid inside. once that fluid loses it's viscosity then it stops working.
