ae86 with a VQ with problems...
Hey guys I just got the motor to start and it goes into
limp mode for no aparant reason. Scanned for codes and it gets a 1610 NATS code and a 1001 CAN COM code. I spoke to my tuner and he said that it should show those because Im only running the engine harness and nothing else. Anyone have any ideas?? Because Im so stumped on this one. 03 motor and ecu flashed for NATS removal by UpRev Thanks Heres a video BTW http://www.youtube.com/watch?v=Z6nc8FODr_Q |
It's confused since it's in a toyota.
good project. goodluck
Because it doesnt like yo AE86..... Contact Uprev.
Yes you are going to have to have the ECU dumbed down by uprev
well the ECU has been dumbed down by uprev, my problem is weird now the
throttle body is working like 2% of the time. whenever I turn the key to on the throttle body just clicks like a relay sound and once in a blue moon it starts to have that high pitch wine like its supposed too. now is it supposed to work with the key just on the on without starting the motor??? PS merry christmas!! |
Should have just bought a z....
You may try doing a throttle relearn on it for the TPS. I know from research that if you mess with the throttle blade with the engine off it will screw with it. Also you could try replacing the the TPS, and the throttle body just to check it. Call uprev or email jared they are always willing to awnser my questions.
Hey Jay'Z way to go to ruin another thread with your mindless babbling. Seems like that is all you do, have to get your post count up. |
didnt you went from a KA24DE then / s2000 motor ?
good luck |
Originally Posted by rocks
(Post 8019120)
Originally Posted by NiZMo1o1
(Post 8029070)
good luck |
