GT4 350Z Chassis with an LS2
5 Attachment(s)
Hello all,
I have been working on my project since 2005 ... had a number of stops and other issues .. but at any rate, I wanted to build an FIA GT4 350z race car with a VQ35DE engine, but after receiving my VQ35DE engine and spending a lot of $$$$, I wanted to get a dry sump system, and that was more $$$$ and that was it, I could not justify paying more $$$ for something that I know other engines platform were paying much less for .... So I sold that engine and decided to go with an LS engine and never looked back. The below pictures were taken earlier this year during the roll cage install which was designed by RJN Motorsport in the UK and is FIA GT4 approved roll cage |
4 Attachment(s)
Some more pictures and as you can see some of the body was cut to save weight ...
3 Attachment(s)
Some more pics and specs
The car will have a MoTeC M880 Stand alone ECU with an SDL dash hooked to a GPS. Endless brake system, plus some other goodies :-) These pictures were taken around July this year when the car came back from the roll cage install. |
5 Attachment(s)
In these pics:
1) First we cut the floor and firewall, to make room for the Tilton pedals 2) Also we installed the Woodward steering parts including steering column 3) we also welded all of holes and openings that the chassis had 4) painted the car from the inside and the engine bay |
4 Attachment(s)
Some more pictures
ohhh yeah we also cut the floor in the back for the fuel cell, which is a custom ATL, around 25 gallons capacity. |
4 Attachment(s)
Some pics of the fuel cell bladder, I'm just waiting on the FPR and filter and the Tilton pedals, and as you can notice, the setup is a DBW using the Nissan accelerator.
4 Attachment(s)
Here is the engine and the T56 Magnum getting ready to go in ...
In the other picture you will notice the ATL shoe box in the back of the car .. After the installation of the engine we noticed that its a bit higher than what we would want and was at sitting on 12 deg tilt, so we made a new engine mounts and trans mount so now the engine is at 4 deg tilt and much lower. Not to mention that in order to lower the engine we had to convert the steering rack to manual from power which also allowed us to take out the power steering. |
5 Attachment(s)
In this set of pics you can see the how low the engine is ... other than that you will you see that we mounted the radiator in a "V" configuration which lowers the CG and also move the weight closer to the front axle ... the next step is to install the oil coolers and air guide
5 Attachment(s)
we finished the radiator air duct and installed the oil coolers,which will also get its own air duct from the side of the radiator.
This is a list of the major parts that is/will be on the car:
TEIN Tie Rod & Tie Rod End Milling Hi flow Oil Pump Central 20 3.9 Final Drive Driveshaft Stage 5 Half Shafts Cusco LSD Type RS SSR GT3 18x9.0 +31 - 18x10.5 +43 Cusco Front Adjustable A Arms RJN Motorsports GT4 Roll Cage Woodward Quick release look & Steering column Solid Engine Mount JIC Magic Rear Traction Rod SPL Aluminum Solid Diff Bushing Sets SPL Stabilizer Endlinks Battle Version Toe Arms Endless - Front 6 pot 345/32mm - Rear 4 pot 332/30mm 350EVO Adjustable Sway Bar Kit Hinson mounting parts LS2 engine - Around 500 BHP LS T56 Bellhousing Spec Light Flywheel and Clutch & Hydraulic Bearing Release ARE Dry Sump System RPM T-56 Magnum 6 Speed Transmission Billet Pro Series T-56 Shifter NISMO Front Lower Transverse Link Bushing NISMO Rear Upper A Arm Bushing NISMO Rear Lower Link at Hub Bushing NISMO Rear Radius Rod at Hub Bushing Koyo Aluminum Radiator - 53mm core Aerosync NISMO Replica Front Bumper Setrab Oil Coolers Locking Vertical Hyd Handbrake Tilton Pedals Set Motec M880 ECU LS MoTeC Harness MoTeC SDL Sport Dash MoTeC Shift Light Sibon Carbon Fiber Doors and Hatch Esprit Acrylic Windows APR Front Bumper Canards APR GT 300 Wing Schroth 6pt Hybrid II Racing Harness Seibon Fenders (10mm wider) Seibon GT Style Hood Sparco EVO L Seat Sparco Steering Wheel 285 Steering Wheel Hook - 1 3/4 Battle Version Camber Arms ATL Fuel Cell |
Gorgeous
thats some awesome work, so with the engine change what kind of racing will you be doing now? I would imagine a 350Z with an LS2 kind of removes you from the official FIA GT races?
wow...talk about dedication!
Originally Posted by idrive_MD
(Post 8766741)
Az |
awesome
looks great. get some vids
in4thevideo when the time comes...
Thats awesome
Awesome project. Glad that you stuck through the finish. Keep us updated to the end.
crazy work...deff make some vids when that car is rippin
