MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Engine & Drivetrain (https://my350z.com/forum/engine-and-drivetrain-50/)
-   -   Rambo's LS6 G35 Build (https://my350z.com/forum/engine-and-drivetrain/548266-rambos-ls6-g35-build.html)
Rambo Feb 13, 2012 06:28 PM
Well my engine is burning oil so I decided to replace it with a new one. I am building a 400+hp LS6. Had this on G35Driver for a while so I thought I would catch everyone up.
So far my build setup is as follows:
1. 01' LS1 Longblock ($650) - Just checked the casting numbers. I have an LS6 block!! About 15% of the blocks in 01 fbodies were ls6 castings. I am excited.
2. 243 heads ($350)
3. Mahle Power Piston Pack ($425 - new bought from someone on LS1TECH)
4. ARP Main Studs - $180
5. Clevite 77 Cam Bearings - $35
6. All block and head machine work, Rotating Assembly Balanced, Main Bearings, Rod Bearings, and ARP Rod Bolts - $1335 (Huck's Machine Shop in Cincinnati, OH - Highly Recommended)
7. ARP Balancer Bolt - $25
8. LS2 90MM TB - $125 new (best ebay find ever!)
9. LS2 Intake and Fuel Rails - $250 (purchased from VAS_33 on LS1tech, going from Z to G)
10. EPS 226 INT./230 EXT. .600 lift custom cam - $400
Total so far: $3775
Just got it up on the engine stand today to inspect...
https://lh5.googleusercontent.com/-x...s576/Ls1-1.JPG
https://lh6.googleusercontent.com/-y...s800/Ls1-2.JPG
Dirty Pistons:
https://lh5.googleusercontent.com/-r...s576/Ls1-4.JPG
Clean Piston (4 down, 4 to go):
https://lh5.googleusercontent.com/-b...s576/Ls1-3.JPG
After I finish cleaning the last 4, next step is to press out the wrist pins. I am going to reuse the stock rods.
243 heads from an LS2. I am going to clean these up, polish, and put some high lift springs and comp cams trunion upgraded rockers. I think it will go nicely with a phat cam...
https://lh3.googleusercontent.com/-M...10914-2154.jpg
mmm....new pistons!!!!
https://lh6.googleusercontent.com/-5...0/pistons1.jpg
Installed new ARP Main Studs today!
Old stock main bolts out.
https://lh5.googleusercontent.com/-3...s800/photo.JPG
Dropped in the new studs.
https://lh4.googleusercontent.com/-v...0/DSC_2423.JPG
All done. Ready for the machine shop!!!
https://lh3.googleusercontent.com/-7...25281%2529.JPG
Time for an update.
Total list of things Huck's Machine Shop did for me:
1. Clean Block, Valves, Valve Covers, and Heads
2. Inspect and Deck heads flat
3. Magnaflux Crank, Grind, and polish
4. Inspect block
5. Bore, hone, and match block to pistons
6. Recondition stock rods with ARP bolts
7. Assemble rods and pistons with pressed in wrist pins (THEY DID IT FOR FREE!!)
8. Replace cam bearings
9. Full balance of rotating assembly
10. Ground flywheel (THEY DID IT FOR FREE!!)
11. Furnished Main and Rod bearings
Final machine shop cost with ARP rod bolt, main bearings, and rod bearings: $1335.41
Time for pics:
Freshly Cleaned, Bored, Honed Block:
https://lh3.googleusercontent.com/-1...0/IMG_0668.jpg
https://lh4.googleusercontent.com/-B...0/IMG_0670.JPG
https://lh6.googleusercontent.com/-b...0/IMG_0669.JPG
Is that Chevy Red-Orange I see:
https://lh4.googleusercontent.com/-1...0/IMG_0671.JPG
Why yes, yes it is:
https://lh5.googleusercontent.com/-J...0/IMG_0680.JPG
https://lh3.googleusercontent.com/-i...0/IMG_0679.JPG
https://lh6.googleusercontent.com/-s...0/IMG_0676.JPG
https://lh5.googleusercontent.com/-n...0/IMG_0675.JPG
Fresh Parts!!!
https://lh4.googleusercontent.com/-l...0/IMG_0672.JPG
Piston Assemblies:
https://lh4.googleusercontent.com/-b...0/IMG_0683.JPG
New Piston Assembly with ARP Rod bolts and MAHLE Pistons:
https://lh3.googleusercontent.com/-_...0/IMG_0673.jpg
Freshly Ground and Balanced Crank:
https://lh6.googleusercontent.com/-b...0/IMG_0684.JPG
Cleaned and decked heads:
https://lh3.googleusercontent.com/-H...0/IMG_0682.JPG
I also got the fly wheel, rod, and main bearings. Time for short block assembly to begin....
New micrometers for verifying clearances. New bore gauge is on the way!!
https://lh4.googleusercontent.com/-q.../s640/mics.jpg
JEGS SENT ME THE BORE GAUGE WITH MISSING PARTS!!!! WTF!! (Finally got a new one)
https://lh6.googleusercontent.com/-y...NG%2BPARTS.JPG
Just bought a piston ring filer and a ring compressor tool. Lets see if they come in with all the pieces;)
http://paceperformance.com/images/M24307115.jpg
http://paceperformance.com/images/M24307362.jpg
Just picked up a new LS2 90mm TB for my build. I will be upgrading the LS6 to alot of the LS2 stuff. $125 bucks new - Ebay find of the century
https://lh5.googleusercontent.com/-l...k/LS2%2BTB.jpg
OK. Time for an update.
Lower main bearings installed in the main caps.
https://lh3.googleusercontent.com/-m.../IMG_00020.jpg
Upper main bearings installed in the block.
https://lh3.googleusercontent.com/-w.../IMG_00021.jpg
Erica's first attempt at taking a picture of me micing in the main bearings, pretty cool shot though:
https://lh5.googleusercontent.com/-S.../IMG_00022.jpg
Me micing in the main bearings. .001"-.002" clearance all around. Yeah!!
https://lh5.googleusercontent.com/-x.../IMG_00023.jpg
All main bearings checked out to .001"-.002" clearance. She is ready for the crankshaft.
https://lh4.googleusercontent.com/-a.../IMG_00024.jpg
A little assembly lube on the upper main bearings.
https://lh4.googleusercontent.com/-h.../IMG_00025.jpg
A little more assembly lube on the lower main bearings.
https://lh5.googleusercontent.com/-9.../IMG_00026.jpg
Dropped the crankshaft in!!
https://lh5.googleusercontent.com/-Z.../IMG_00027.jpg
Main caps installed and everything torqued down. She turns freely. Next step is to check end play.
[https://lh3.googleusercontent.com/-k.../IMG_00028.jpg
Thats all for today. I am still waiting on my ring grinder and ring compressor. Should be here later this week.
New ARP Balancer Bolt is in!! Should be assembling the pistons in the short block this weekend.
https://lh4.googleusercontent.com/-i.../IMG_00029.jpg
Decided 50 bucks was way too much to spend for a piston ring squaring tool. So i made one. Turned out great, not bad for $FREE.99
https://lh4.googleusercontent.com/-n.../IMG_00030.jpg
Checked crankshaft end play. Looks good. I also finally got the piston rod bolts loosed up so I can start assembly of the bearings
https://lh4.googleusercontent.com/-q...IMG_00031a.jpg
Time for an update!!
The rod bearings and connecting rod/piston assembly.
https://lh4.googleusercontent.com/-k.../IMG_00035.jpg
Dropped in the rod bearings.
https://lh5.googleusercontent.com/-Y.../IMG_00036.jpg
Bearings are ready for clearance inspection. Seven more to go...
https://lh4.googleusercontent.com/-l.../IMG_00037.jpg
All the Piston/Rod assemblies ready for rings.
https://lh6.googleusercontent.com/-x.../IMG_00039.jpg
My piston ring squaring tool works!!
https://lh6.googleusercontent.com/-q.../IMG_00040.jpg
Piston ring #3 all gapped up and ready to go.
https://lh5.googleusercontent.com/-6.../IMG_00041.jpg
The full piston assembly rings, rods, bearings, and pistons. The whole caboodle ready for assembly.
https://lh4.googleusercontent.com/-N.../IMG_00042.jpg
Piston rings installed.
https://lh6.googleusercontent.com/-L.../IMG_00043.jpg
After a ***** of time figuring out how to get my ring compressor working correctly (wouldnt close all the way) on piston #1 the rest dropped in nicely.
https://lh4.googleusercontent.com/-0.../IMG_00047.jpg
https://lh4.googleusercontent.com/-k.../IMG_00048.jpg
Bottom end all buttoned up!
https://lh6.googleusercontent.com/-a.../IMG_00050.jpg
ARP Rod bolt close up!
https://lh6.googleusercontent.com/--.../IMG_00051.jpg
https://lh5.googleusercontent.com/-I.../IMG_00052.jpg
All Pistons In!!! Time to find a cam!!!
https://lh3.googleusercontent.com/-C.../IMG_00049.jpg
btw this build is sponsored by budwieser. 5 hrs of working on a motor cannot be had without a few cans of beer.
2004Black350z Feb 13, 2012 06:58 PM
Great thread
bbs350z Feb 13, 2012 07:09 PM
in for this. lookin great!! apparently 1 thing to look out for is making sure you have the right crank position sensor, just a heads up.
EmpireDude Feb 13, 2012 07:24 PM
glad to see someone local. I'm just up in the Dayton area :) very cool!
ImWeeZzel Feb 13, 2012 07:31 PM
good luck w/your build, suscribed' for progress
Z33Garage Feb 14, 2012 06:05 AM
:D subscribed
Vas_Z33 Feb 14, 2012 06:23 AM
very nice!! I would contact patrick G for a custom cam. Shoot me a PM if you want more info.
mvp2765 Feb 14, 2012 06:32 AM
dang, looks good!!!
bigcloud Feb 14, 2012 08:09 AM
Sick build man. Can't wait to see this all finished and running!
flecko28 Feb 14, 2012 11:02 AM
sub'd
good luck! looks great so far...very jealous
BornSlippyZ Feb 14, 2012 11:16 AM
Sweet another LS swap!
mw9 Feb 14, 2012 02:29 PM
In for updates, in Cincinnati also, have to see it when your finished
Rambo Feb 14, 2012 03:20 PM
Ditto that!! I have the 24X reluctor. I am going to run the E40 ECU so I can run LS2 sensors. I have spent alot of time reading about this.
Czarrr Feb 14, 2012 03:26 PM
Thank you for including prices.
It helps gives us noobies an idea of the cost.
Rambo Feb 14, 2012 03:29 PM
Thats the idea. I got the idea from Royal_Ts thead. This way people can compare true costs from the ground up.
Brew_haha Feb 16, 2012 01:53 PM
If you have any questions prices on swap kits, wiring harnesses, and swap parts PM me. I have a build thread on g35 driver just search my user name. Iv been through the build and can tell you the easy way through it.
2004Black350z Feb 16, 2012 02:00 PM
Keep up with the cost please
Rambo Feb 17, 2012 06:00 PM
Just got an LS2 Intake manifold from Vas_33 (somehow randomly bought his on ls1tech) so I can use my 90mm Throttle body. I am going to port this one, then some day get a FAST set up down the road.
https://lh4.googleusercontent.com/-g.../IMG_00053.jpg
https://lh6.googleusercontent.com/--.../IMG_00054.jpg
CRIDDA Feb 18, 2012 08:16 AM
sub'd. Looking good so far:thumbup:
Rambo Feb 20, 2012 02:15 PM
Just purchased an EPS 226 INT./230 EXT. .600 lift custom cam today....2 weeks and counting until I get it!!
