Bypassing OEM transmission oil cooler,
I need to replace the oem radiator in my car ( 5AT ) because it's cracked and leaking pretty bad at the top plastic tank.
I was thinking about buying an all aluminum radiator like the koyo performance & buy a standalone transmission cooler like a setrab 19 or 25 row coolers, But i'm not sure if it will be sufficient enough !!! Anyone ideas ? |
unless youre running a big turbo build a OEM replacement will be fine. You may want to do a little research on the combined radiator transmission cooler. I'm sure a 19 or 25 row will be more than ample but cooler transmission fluid doesnt mean it'll lubricate better. I believe nissan combined the radiator and transmission cooler to keep the transmission fluid at the 200*-210* coolant temperature range as that they have determined the fluid lubricates best at this temp.
Do your research and see if this is correct - I would look for an aftermarket unit that combines the radiator and tranny cooler in one unit similar to how your OEM radiator is. |
The size of the OEM cooler us actually about the size of the PS cooler, a small trans cooler will be fine.
Originally Posted by bealljk
(Post 10553057)
unless youre running a big turbo build a OEM replacement will be fine. You may want to do a little research on the combined radiator transmission cooler. I'm sure a 19 or 25 row will be more than ample but cooler transmission fluid doesn't mean it'll lubricate better. I believe nissan combined the radiator and transmission cooler to keep the transmission fluid at the 200*-210* coolant temperature range as that they have determined the fluid lubricates best at this temp.
(Post 10553057)
(Post 10553082)
fyi the mishimoto is more than 2x as thick as the oem radiator core and it is all aluminum. I have one on my car and it works great.
1 Attachment(s)
Originally Posted by jdm-v35
(Post 10553150)
This is the only one from mishimoto with trans cooler, link Attachment 461141 |
youre on the wrong item. says OEM replacement.
they sell OEM and racing versions. I would call them to make sure it has the trans cooler though. I have a G35 and mine had it, but they make revisions so even mine was different from what they had shown but revised to be better. edit: according to Z1's website it says no auto cooler for 350z model. I would say use a g35 radiator or add a trans cooler with inline thermostat to maintain the temp. http://www.mishimoto.com/nissan-350z...diator-03.html |
(Post 10553253)
Originally Posted by Unbootable
(Post 10554113)
Do you think that a thermostat will still be needed even in such ambient temps ( i'm talking about 110 degrees most of the year ) ?
(Post 10554113)
(Post 10554113)
(Post 10553057)
Do your research and see if this is correct - I would look for an aftermarket unit that combines the radiator and tranny cooler in one unit similar to how your OEM radiator is. That mishimoto rad. is nice & is double the thickness (2 rows) of the oem but the transmission cooler built within is no larger:icon22:. I called & spoke w/someone @ mishi a couple weeks back. Bummer. |
