rebuilding DE help with cams
okay im doing a full rebuild of my 03 de only things staying are the heads and the block, ive got about no idea about cams other than if you want more than 11mm lift then you have to replace pistons and the valves, right now I know I want the tomei brand and I would *like* to have the most aggressive cams possible, ill have Ferrea valves and springs and ill have WiseCo pistons, with that said how which of the procams can I handle? (intake 280 11.3 exhaust 280 11.0?) my apologies if I sound like a complete noob Ive got very little knowledge of cams.
What are your plans for the intake side of things?
Originally Posted by dnash
(Post 10958719)
Originally Posted by 03350
(Post 10958701)
it's ok to be a noob and ask questions but please do it in a respectful, humbling way, with no arrogance, and no attitude (NOT that you haven't already - you're good thus far) but new members come in and ask noob questions with attitudes and disrespect to long time members and they don't last long. Once you know what you want to do with the car find someone else on the forum that has done what you are looking to do and mimic what they've done. A few things to think about and some basic pricing: What are you going to tune with ($1000 - $3500)? What fuel system are you going to run ($1500 - $2000)? What exhaust setup do you want to run($1000)? You'll need more intake work to optimize a large cam setup ($500 - $1000) |
Scroll to the bottom of the page and have a look at the dyno graphs.
http://www.tomei-p.co.jp/_2003web-ca...82_cam_VQ.html Bigger isn't always better. If you don't have the intake (and exhaust) flow to support the big cams, all you are doing is trading a cool idle for little and in some cases, less power. Personally, I think you might be better off with a set of 264s from any of the various manufacturers. That said, it's your money and your car so if you think it will give you more enjoyment and street cred then by all means giv'er. |
Originally Posted by bealljk
(Post 10958843)
what do you plan to do with this car after all the work is done
(Post 10958850)
(Post 10958880)
In the long run I will be going FI so right now I want to get it completely ready for that
(Post 10958879)
as of right now the only things im doing (because its all I have money for) is forged internals tomei from headers back and ferrea valves (ordering lvl3 z1 rebuild kit) my plan for the car at the very moment is built the best N/A I can before doing all my suspension work and after thats all done ill come back and turbo in some way (super charger or twin) what else will I need to do intake wise for me to be able to put the larger cams in now so it saves me having to do it when going to FI, also thanks for not being a dick
My feeling is you are taking two step forward and one step back. You're not going to see much, if any gains: A. without a tune … is your plan to rely on the original Nissan OEM ecu & tune?? B. rely on the OEM MAF / OEM Throttle body, and the upgraded AEM intake as your intake track?? I don't know how this is going to work? If at all … can the OEM ecu handle a different cam profile? If money is an issue (and nothing wrong with that) go with the upgraded pistons and go with OEM cams … spend your next chunk of money on your exhaust work ($1000), plenum work($250), and then on an Uprev tune (+/- $500) … this will yield +/-30hp. when the time comes to go supercharger/turbo, then do your cams, valves/springs, and any other internals work required. You'll have your intake done, you'll have a tuning solution, your exhaust will be ready and you can focus on FI.
(Post 10958879)
What compression are you aiming for with the forged piston? I would look into a 3.5" intake (a tune is needed for this) at minimum and probably a Kinetix Velocity intake manifold on the intake side. At this point, you are likely going to need bigger injectors as well but you can find used GTR injectors for pretty cheap.
(Post 10958881)
getting ready for FI may be out of your scope for this round of upgrades …
This is sorta a weird place to be … you're looking to do the deepest/hardest mods while the block is out...completely logical My feeling is you are taking two step forward and one step back. You're not going to see much, if any gains: A. without a tune … is your plan to rely on the original Nissan OEM ecu & tune?? B. rely on the OEM MAF / OEM Throttle body, and the upgraded AEM intake as your intake track?? I don't know how this is going to work? If at all … can the OEM ecu handle a different cam profile? If money is an issue (and nothing wrong with that) go with the upgraded pistons and go with OEM cams … spend your next chunk of money on your exhaust work ($1000), plenum work($250), and then on an Uprev tune (+/- $500) … this will yield +/-30hp. when the time comes to go supercharger/turbo, then do your cams, valves/springs, and any other internals work required. You'll have your intake done, you'll have a tuning solution, your exhaust will be ready and you can focus on FI. my new years resolution was to be less of a dick on my350z.com … (again thanks for not being a dick this is some of the most helpful information ive gotten using my350z) |
(Post 10958887)
just looked at intakes they are about a G not a big deal the car is already going to be down for a couple weeks won't be a big deal to get one in while she's down
(Post 10958925)
11.0 as I don't have enough money to go FI right now I figured that would be better, if im wrong I can definitely have them switched over to 8.8 no big deal as for my intake mani I got no problem ordering one especially if its anyway prettier than the stock nasty one lol as for the injectors I figured I was going to need bigger ones but will I also need fuel rails to help support them or am I just being noob (thanks for the reply)
(Post 10958926)
let's see a picture of this work you're doing here bud |
JE makes a 10:1 FSR piston that might work ok with forced induction. Its a touch less than stock but it might save you some momey/headaches when it comes time for forced induction. Have you given any thought to the oil pump?
Originally Posted by vegasanthony
(Post 10958933)
This Thread totally sucks without pictures
(Post 10958924)
I completely had forgotten tune side of things, ive definitely gotta do some research on what ecu I want to upgrade to and what tuner id like to take the car to but yes ill be having a new ECU tune and a new throttle body as for the MAF I didn't put thought into sensor side of things (ima dumb dumb) and as for my plenum should I just order a kinetix one to come with the rest of my parts? I don't think they cost but like 400 bucks or something (don't kill me if im wrong)
(again thanks for not being a dick this is some of the most helpful information ive gotten using my350z) Look into Motordyne's spacer and lower plenum modifications - those are going to be your best bang-for-your-buck. I'm not a fan of the Kinetix stuff. You don't be a dick and we wont be dicks - why this isn't clear to every new member is beyond me … everyone was a beginner at some point in time. You'll have plenty of opportunities to help someone along the way...You owe each one of us a beer, and I like bud light lime...
(Post 10958925)
(Post 10958942)
oil pump?
and throw some pictures up of the car... |
1 Attachment(s)
(Post 10958958)
that's alright, that's why were here
look into Uprev
$500 to $1000 is going to be your best bet...and it'll take you into FI. Uprev is the best all inclusive solution for the lowest cost that doesn't skimp on the features you need. Additionally, plenty of support available.
Look into Motordyne's spacer and lower plenum modifications - those are going to be your best bang-for-your-buck. I'm not a fan of the Kinetix stuff. You don't be a dick and we wont be dicks - why this isn't clear to every new member is beyond me everyone was a beginner at some point in time. You'll have plenty of opportunities to help someone along the way...You owe each one of us a beer, and I like bud light lime... If it was me, I'd go slightly lower than 11:1 if FI is your ultimate destination...something in the 9:1 to 10:1...if NA is your ultimate destination than go with an 11. def something to consider when you go FI and throw some pictures up of the car... im gonna go with the 8.8 compression so that I will be able to have my car more ready for twin turbos after suspension, ill definitely get the motor dyne lower plenum, will I need to get a new upper as well or will stock do just fine and im gonna for sure buy uprev standard and upgrade to tuner when I turbo Theres a pic of her, right now its in Tennessee and it will be delivered to me in Arizona the first week of July, im aiming to have the parts here by the time it gets here but im taking a little longer than I thought I would getting the complete list together |
(Post 10959155)
Originally Posted by iideadeyeii
(Post 10959184)
No-one goes that low compression unless you're going very high hp(which you're not)
+1 ... get into the 9 point something to 1 ...
