Voltage drop issue!!
Hello guys I have a 2003 350z with 142k miles. I purchased this Z off someone who unfortunately neglected my baby :icon22: one of the things they did was they drove the car extremely low on jacked up coils and scraped off my 02 bank 2 sensor 2 connector. They used some male and female disconnects to fix the issue they caused. I’ll insert pictures. Does anyone have this issue or can they look under their DE and tell me which wires on the o2 sensor 2 go to the wires on the sensor connector? I’m also getting random voltage drops while driving my car. I’m just wondering whether or not this is the issue or that my camshaft position sensors having oil on them is causing it. |
if you're looking at the sensor connect head on and the locking mechanism is at the 12 o'clock position:
Top Left: Black Top Right: White Bottom Left: White Bottom Right: Grey I dont know how to distinguish the two whites but it may not matter. They may be a voltage feed. |
I'm looking at replacing an upstream sensor myself. Any advice for best practices on wiring connectors?
just replace the whole sensor ... you don't need to re-pin anything
How can I replace the whole sensor even if it’s sheared off?
Originally Posted by bealljk
(Post 10975600)
Do you think..
(Post 10975565)
Originally Posted by Evanryno55
(Post 10975703)
you think my voltage dropping issue while at idle could be because I need a new valve cover gasket and my camshaft position sensors have oil in them??
