Broken NAV cubby door
Ok.. I broke it. I knew it was coming. anybody know how to fix a broken cubby door??
Really??? Want to offer up any info at all on exactly what is broken??? :dunno:
A little more info and you should be able to get some help. A pic could help too. I am assuming it is 03-05 if it has a door. |
Originally Posted by jekl1000
(Post 6868687)
Read the subject line. HAHA
do you have the cubby area, or is the nav unit there? the motorized door for my nav unit quit working so i took the assembly apart and messed with some stuff to figure out what was wrong. turns out the little button that you push was bad. for the meantime i just put the door in the open position so the switch that turns the screen on was tripped. door is permanently open for now and the screen works.
Originally Posted by urbancamoM7
(Post 6869982)
Originally Posted by steveiZdaman
(Post 6870047)
thats also what i did with mine...my nav door hasnt worked for 2 years now...i went through like 2 new doors and motors from the dealer then finally told them to leave it in the open position and disconnect the door...so my nav still works but the door is open all the time
(Post 6870104)
exactly. plus if the screen is too bright during the night you can go into the display settings and just turn it off. i only used it to keep track of oil change mileage anyway. :)
Originally Posted by Shiro
(Post 6869939)
Wonder why you have almost 100 views and not many responses? |
(Post 6872029)
HAHA, I did. Where does it say if it is the hinge, the latch, the back of the door that screws to the fascia, etc.
(Post 6870104)
Thanks |
Originally Posted by cer2225
(Post 7359304)
Mine is starting to make noises and needs a little help to open. I was thinking of just leaving it in the open position also but need to know where to disconnect the motor once it is open. Anyone have an idea as to what is the best way to do that? I really don't want to pull the dash apart if I don't have to.
Thanks |
(Post 7359709)
I don't have a motorized cubby so I can not be much help with an alternative way to unplug it. But I can say that removing the center bezel is amazing easy. It is only 8 screws and 6 of them are all in the same vicinity. Otherwise, have you looked into a new motor?
I am sure there is a sticky on how to remove the center console on here somewhere. I will check it out. Thanks for the suggestions. |
(Post 7360450)
I did not look into the motor yet. I did buy the top tier extended warranty but I doubt that would be covered.
I am sure there is a sticky on how to remove the center console on here somewhere. I will check it out. Thanks for the suggestions. https://my350z.com/forum/audio-video...y-monitor.html Good luck! |
Thanks much...
Thanks guys, Sorry I only have an empty cubby and no NAV as I have the performance pkg. As far as I know it is spring laoded w/ some gears in there to make it operate smoothly. I have a 2003 so Im pretty sure there is no motor to open the door, but it wont stay closed and wont open fully and it is driving me nuts. I will look at a few of these links to see how to get the center console out. THx again
^LOL at your 4 month later response.
