walbro fuel pump can't fit the stock pump bracket!! Please help!!
So, I took off the stock fuel pump and try to install the walbro in the housing, but I can't put the clip on support bracket at the bottom to go in and lock. Can I just put a cable tie to hold it? Please help!!:o
only 19 posts ago...
HOW TO: Install a Walbro GSS342 |
But I can't open the link to view the instructions:(
Have you looked at the Turbonetics instructions yet? http://turboneticsownersclub.com/tur...icsinstman.pdf
If I am running stock fuel rail and 440 cc injectors with the vortech, do I need to drill holes or remove anything from the fuel pump assembly?
Follow Phunks directions to the T. It is not hard!!
Basically just to install the pump?:)
Thanks for all the input guys!!!!:) |
u need to shave off the 2 circular black tabs
why cant you view the link i posted?
link removed.. you can delete my quote if you want
Alternatively, my wife and I posted our Walbro experience
https://my350z.com/forum/forced-induction/304690-revup-vortech-installation-joining-the-ranks-of-fi.html I hope it helps. We didn't get any pictures before we buttoned it all up but the written description is very good.:) |
I finally view the link, and the step by step is awesome. Thanks phunk:)
:) let us know if you run into any issues
Thanks:o |
| All times are GMT -8. The time now is 02:14 PM. |
