Vq engine for sale, good for 1875whp !!!
I find this posted in a local forum and I don't why but I think there is something wrong here.:dunno:
The listed below are the installed parts: VQ35DE Engine plus shipping $3,700.00 Crower Forged Rod & CP Pistons 8.5:1 CR Stock Bore (Race Engineering 02/2005) $2,350.00 ARP Heads, Main & Rods Studs $600.00 TOMEI 268 duration with 10.5 mm lift Camshafts Set $1,400.00 Darton MID Block Sleeves $2,350.00 Ferrea Super Alloy Valves (F1565P) Exhaust Side 22° Flow Radial Groove +1mm $500.00 Ferrea Competition Plus Valves (F1563P) Intake Side 20° Super Flow Radial Groove +1mm $500.00 Ferrea Valve Springs Single Spring Special Alloy $440.00 Ferrea Titanium Retainers (E11058) 6mm $375.00 Ferrea Steel Valve Locks (K10069) 6mm Radial Groove $320.00 Ferrea Spring Seat Locators (SL1048) $420.00 Ferrea Copper Alloy Valve Guides (VG1041) Exhaust + .001 Over Size $500.00 Ferrea Manganese Bronze Valve Guides (VG1039) Intake + .001 Over Size $500.00 Ferrea Valve Seals (VS1012) Exhaust 6mm Valve Steam. Viton Rubber Compound. $35.00 Ferrea Valve Seals (VS1014) Intake 6mm Valve Steam. Viton Rubber Compound $35.00 Nissan Main and Rod bearings, Nissan Cam seals, Heads gasket match, Valve Stem Heights set $450.00 Combustion chamber cleanup, Block Bored and Honed using a Torque Plate $250.00 Cometic Metal Heads Gaskets, Balance Rotating Assembly, Block re-decked, Cold Clearance set $2,250.00 Ported and Polished Intake & Heads (exhaust and intake runners) with 3 angle valve job $2,250.00 Heads oil passages cleaned, Heads re-decked, Block oil passages cleaned $214.00 Tilton Carbon Triple Disk Clutch & Flywheel $4,250.00 NISMO Oil Pump $1,014.00 CJM Fuel Rails High Luster Polished $361.00 RC Injectors 1000cc without clips and 0.480" spacers - Dead time is 1.2 msec $450.00 ARP L19 11MM Head Studs $490.00 SVRT Head Lifting Fix Studs $110.00 Injected Performance Solid Engine Mount $295.00 Denso IKH20 Spark Plug 350Z (2 steps colder than stock heat range) priced per set of 6 $72.00 Parts included but not installed: HKS DLI $580.00 SGP Racing Chromoly Pivot Ball $39.95 SFR Twin TB manifold and pipes and a TBs (With vacuum outlet) – listed below SFR Inter Cooler 2nd outlet $4,000.00 Injected Performance VQ35DE Billet Girdle $450.00 Pathfinder cooling upgrade $275.00 All of the above cost is more than (((US$ 30,000.00))) and it’s up for sale for the highest bidder The same engine was able to produce around (((1,875whp))) :rolleyes: |
Sounds expensive
lets see the link so we can have some fun :icon38:
^^ It's in Arabic. loool
stay away from it.. when you buy a built motor.. you want an intimate relationship between yourself and the builder.. not between third parties
that's somethin fishy... i've got pretty much the same setup, minus a few things... the sleeves and the larger valves. so i'm excited to see it come back from the machine shop. if it makes 1/4 of this claimed power, i'll be happy!
I'm not saying I will buy the engine (actually I have 08 and I will DIY my GTM HR TT next week) I just thought about sharing this.
1,875whp....hmmm I'd love to see a dyno of that.
in for dyno
who a highest hp Z world record again?
post link and i will translate
The funny thing here that most of the builds here got the same parts and none of them near 1875whp.
Originally Posted by wannabuy350z
(Post 7500060)
Be my guest http://www.kwtmotor.com/vb/images/smilies/shesha.gif http://www.google.com.sa/search?hl=a...a=lr%3Dlang_ar |
Nissan Main and Rod bearings RC Injectors 1000cc is this another RA build sheet? |
Originally Posted by midz350
(Post 7498778)
I haven't seen one boosted VQ35 in kuwait in the 4 months i have been out here. Let along any tuner shops around da way. |
WOW are you FOR REAL.. i guess no low oil press wit this part..
NISMO Oil Pump $1,014.00 |
(Post 7500065)
+1:icon18: Hilarious
i WANT this engine, money is no object. PM me with sellers info, ASAP
