My baby is in the shop...and it doesn't look good
So I finally pulled the trigger and started the process to resurrect the Z. '04 PPW Greddy Twin Turbo (stock motor). Last time I drove it, it felt like it was in some sort of limp mode and wouldn't rev past 3k.
I took her to Z Car Garage and upon start up they've discovered that the car is only running on 5 cylinders. NOOOOOOOOOOOOOOOOOOOOOO!!! Leakdown and comp test are in progress now. Boy I hope it's just plugs or something and not the bottom end. :icon14: |
Tests not done yet but he's already warned me that it could run $6500 to replace the rods and pistons. WOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WOW is right!! You can get a built shortblock for almost have that price!! Good luck!
How much HP on how much boost were you running?
Originally Posted by mdcruz88
(Post 7917063)
I got stock rods and pistons i'd sell cheap if you are just looking to replace them
Originally Posted by EL Matador
(Post 7917081)
Originally Posted by SexyRob
(Post 7917164)
Originally Posted by dynamic21
(Post 7917137)
Hmm... I'm not too sure about this, but wouldn't that make it cheaper to just have nissan install a new engine? lol
Originally Posted by 1GR8350Z
(Post 7917130)
Originally Posted by Nexx
(Post 7917198)
:bowrofl:
i think someone mentioned it but why not just buy another built short block?
Originally Posted by pony_killer
(Post 7917309)
I'd be happy running low 12's, high 11's. Totally doable on a stock bottom end with around 390~400hp. Just gotta have a good tune. |
(Post 7917457)
It really comes down to $$$. If the bottom end needs fixing, I may just take up SexyRob on those stock pieces and spend the money on a really solid tune. I've already purchased Osiris Tuner, upgraded MAF, RFS and injectors so I should be set.
Hopefully just a coil pack or something. If it is, hopefully you didn't drive it too long like this, all that unburnt fuel will wash the cylinder walls and make it a permanent 5-cyl engine LOL.
so you need to spend money on internals and don't wanna upgrade for roughly the same price or slightly more for reliability? Who did your tune and who would do your new "solid" tune?
Originally Posted by jumpin800agl
(Post 7917521)
That's the whole thing. I f'd up. I did say it was tuned, however I didn't mention that it was on the Greddy Emanage Blue which is what comes with the turbo kit stock. Not really ideal for dialing in your motor. For a "solid tune" I'm open to suggestions, but my plan was to take it to Mr. Shawn Church. I've heard he does great work at a reasonable price. |
Dude, if it comes to that, at least upgrade your stock rods and pistons. Replacing stock internals with stock internals is like changing a timing belt on a car and not changing the water pump. |
If there is no audible noise, then doubt its dropped a cylider.
Why take the risk again? Even if your not looking for 500 right now you may want it later and you have the kit to support it. and as you've already seen anything close to 400 or more on stock block is risky. I tuned mine down to 375 because I don't want to be in your shoes
| All times are GMT -8. The time now is 11:41 PM. |
