boost guru's...... quick advice needed!
gurus....
i am off to get my vortech custom mapped tomorrow, and wanna know what the 'ideal' ratio i should be shooting for, in advance.... not to discredit the tuner, but im wanting to have numbers already on tap, for comparison purposes..... as well as having a powerful build, i wanna have a SAFE setup too... for now, im running with oem exhaust and cats, if it matters... i will likely be back to the dyno (same one too, i imagine) when the crawford cats, and fujistsubo Y /midpipe & muffler are installed... can i get some advuce please??? thnx sms ps- what size bung is needed for the aem wideband setup?? (havent figured that out yet either) |
forgot to mention....
this setup is using the stock vortech pulleys..... for now.......:icon37: (corvette pulley and shim, maybe after exhaust) |
12:1 ratio is key when you are not at idle. This should be pretty much across the whole RPM band. With a SC it will be ok to run a little lean, no more than 12.5:1 before about 3 psi of boost.
what about at max boost?? (assuming the s/c WILL create more than the 7lbs it shows on the dials now)??
thnx eS |
Re: boost guru's...... quick advice needed!
Originally posted by esemes ps- what size bung is needed for the aem wideband setup?? (havent figured that out yet either) -D |
personally, i dont like to go too rich at lower RPM, becuase you loose lots of torque and snappiness. So I would start at 13.5:1 at maybe 3000rpm, and gradually and progressiveliy work your way down to 11.5:1 at 5000rpm....I would shoot for a flat 11.5:1 from 5000rpm to redline...roughly. Especially with an SC, which progressively builds boost and peaks and redline...your fuel curve should follow that. A TT is slightly different, in that it hits peak boost at 3000rpm or whatever...so you need to get richer quicker..
11.5:1 is on the "safe" side of peak torque/power. You leave a little bit on the table, but you give yourself an extra margin for error, to account for a bad tank of gas, ambient temp changes, voltage fluctuation, etc...etc... |
Originally posted by gq_626 personally, i dont like to go too rich at lower RPM, becuase you loose lots of torque and snappiness. So I would start at 13.5:1 at maybe 3000rpm, and gradually and progressiveliy work your way down to 11.5:1 at 5000rpm....I would shoot for a flat 11.5:1 from 5000rpm to redline...roughly. Especially with an SC, which progressively builds boost and peaks and redline...your fuel curve should follow that. A TT is slightly different, in that it hits peak boost at 3000rpm or whatever...so you need to get richer quicker.. 11.5:1 is on the "safe" side of peak torque/power. You leave a little bit on the table, but you give yourself an extra margin for error, to account for a bad tank of gas, ambient temp changes, voltage fluctuation, etc...etc... i changed the plugs to 1° colder already, to help ensure the safety/longevity...... lets see what numbers the tooner comes up with....... (maybe i should relay this info prior) -eS |
esemes....The guy that tuned my car has been doing it for 25 years , F/I and N/A race cars .Races himself . He did tell me that 11.8 to 12.2 to 1 is Ideal for F/I and 12.8 to 1 for N/A .Let us know how it turns out
| All times are GMT -8. The time now is 03:46 AM. |
