MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   G35/G37 (https://my350z.com/forum/g35-g37-77/)
-   -   Help! Can't Remove my REAR rotors!!! (https://my350z.com/forum/g35-g37/261913-help-cant-remove-my-rear-rotors.html)
dunglan7 Apr 5, 2007 05:00 PM
I'm removing the rear rotor right now. I took off the two torque bolts and the two caliper bolts, but my rotor won't come off. I also don't have my parking brakes on. Do I need to remove any other bolts, or do anything else?
smallello Apr 5, 2007 06:27 PM
If it's anything like the 300zx. You need two 10mm bolts, screw them in, tighten them down and poof - she's off.
imjdoggie Apr 5, 2007 07:31 PM
and a mallet
drifter23 Apr 5, 2007 08:23 PM
+1 On the mallet
drivenCSZ Apr 5, 2007 08:30 PM
those rears a B!tch...for real.
Mike Wazowski Apr 5, 2007 08:33 PM
just bang them bisches off with a big rubber
mallet that is
THE TECH Apr 6, 2007 06:15 AM
Sledgehammer.
raycs7 Apr 6, 2007 07:52 AM
First, use liberal amount of wd or equivalent, leave alone for a short while, then rubber mallet if you would need to reuse the rotor later
TENGAI Apr 9, 2007 11:43 AM
I've done about 6 brake jobs on a few different z's and g's. WD40 and a rubber mallet. Tap, tap, tap and off they come.
Fluid1 Apr 9, 2007 11:44 AM
Stand with your back facing the rotor. Donkey kick.
mdracer76 Apr 9, 2007 11:47 AM
Rubber mallet FTMFW!
delion21 Apr 10, 2007 07:26 AM
DOnkey kick LMFAO!!!!!
Ha ha ha ha ha
Guy the Larry Apr 10, 2007 09:31 AM
:rofl2:
jeremybudd Apr 10, 2007 10:12 AM
WD did nothing for me. I used it 2 times and let it sit for 10 minutes each time. I then got some other stuff PB Blaster I think it is called and they came off 10 minutes later no problem. Rubber mallet too of course.
gqong Apr 18, 2007 05:54 AM
yeah mine were on pretty tight and rusted but i just kept banging the rotor til it shook loose. good luck and i hope you got em by now lol.
z w/ bsck seat Apr 25, 2007 03:34 PM
take your parking brake off . . . .
that and +1 on the bolts through the caliper mouunt
Jason@Riverside May 3, 2007 09:18 PM
I was gonna say turn off the e-brake!
